ABS light is on
Old Jan 8, 2006 | 10:15 PM
Nuke209's Avatar
Default ABS light is on
my friends ls 98 ABS is on, and it's wierd too, nothing is wrong with the brakes, fluids are good, any reason why?
Old Jan 8, 2006 | 10:24 PM
ED7's Avatar
ED7
Default Re: ABS light is on (Nuke209)
The wheel speed sensor might be bad or not reading properly. You need to check the code. His brakes will still be fine , but the abs will not work.
Old Jan 8, 2006 | 10:26 PM
98b18black's Avatar
Default Re: ABS light is on (ED7)
Like previously said...Check the codes...
Old Jan 8, 2006 | 10:33 PM
96teggynonVtec's Avatar
ya i had the same prob with a 96 ls and it ended up being the right rear speed sensor...
Old Jan 9, 2006 | 09:54 AM
street_bliss's Avatar
i had the same prob with my teg i am pretty sure it is the wheel speed sensor, i aint worrying bout it cuase a new sensor is prolly alot of money.
Old Jan 9, 2006 | 11:00 AM
jomama's Avatar
did you drive a little bit with the e-brake (slightly) engaged or anything... that trips it sometimes, but it'll go away after awhile...
manuelesr
Apr 13, 2008 01:08 PM
wrinkly
Jun 8, 2007 07:12 AM
IntegraLs94Cam
Mar 29, 2005 05:24 PM
TerribleOne
Mar 19, 2003 10:59 AM
Dirt
May 22, 2002 12:38 PM
