ABS light keeps coming on
Old Jan 9, 2006 | 07:21 AM
spooncivic1's Avatar
Default ABS light keeps coming on
what is causing the ABS light to keep coming on. it will only do it occasionally, but its getting annoying. the brakes work fine (minus the squeeking)...if i turn off the car and then crank it back up it will go off for a day or so, then it will come back on
Old Jan 9, 2006 | 07:23 AM
fastrunner's Avatar
Default Re: ABS light keeps coming on (spooncivic1)
probably a short in one of the ABS wheel sensors, or a bad ABS computer.
BlackLudeSi's Avatar
if it turns on when you start the car and does not turn off it is something in the abs unit its self. If it turns on while you are driving it is a wheel speed sensor. Hope this helps
Old Jan 9, 2006 | 07:45 AM
ok, it only does it while im driving
would it matter if my ebrake cables arent hooked up (previous owner) or is the sensor only on the front?
Old Jan 9, 2006 | 08:05 AM
DA-nteg's Avatar
Default Re:
My ABS lights always comes on too... It does the self-check like 100 times and then the light pops on... Soo im curious about this too
Old Jan 9, 2006 | 08:27 AM
bdiddy0036's Avatar
Default Re: ABS light keeps coming on (BlackLudeSi)
how much are wheel speed sensors??
Old Jan 9, 2006 | 02:08 PM
Default Re: ABS light keeps coming on (bdiddy0036)
they were 68$ for my old lude im sure somewhere around there
Old Jan 9, 2006 | 02:12 PM
LSracing94's Avatar
mine did that, turned out the battery connection was weak hahaha
Old Jan 9, 2006 | 02:27 PM
Dogginator's Avatar
Daisy... Daisy...
Quit guessing. Check the stored ABS computer codes. You pull these the same way that you pull a CEL.
Check out this thread:
https://honda-tech.com/zerothread?id=978933
Modified by Dogginator at 6:37 PM 1/9/2006
Old Jan 9, 2006 | 02:44 PM
so, wheres the plug for the ABS then? beside the CEL plug?
Old Jan 9, 2006 | 02:50 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (spooncivic1)
It is the same plug.
Old Jan 9, 2006 | 02:51 PM
BrooX's Avatar
IF you have stomped on the brakes really hard recently to make a sudden stop that may have been the problem. As far as a diagnostic goes, you could unhook the battery cables and let everything restart up again. That might do it. At least thats what I did once upon a time.
Old Jan 11, 2006 | 07:13 PM
fastrunner's Avatar
Default Re: ABS light keeps coming on (DA9GUY-637)
ABS doesn't reset like an ECU, doesn't matter if you unplug the battery.
Old Jan 11, 2006 | 07:57 PM
GserpleaSR's Avatar
it would help if could get a scanner and pull some codes! about 50 things could cause that light to come on! if it comes on when you start to drive its most likely a speed sensor! make sure all four are pulg in!
Old Jan 11, 2006 | 08:09 PM
92gisser's Avatar
mine did the same exact thing. mine was one of the rear wheel sensors...i'm sure yours is the same. gl with it, pretty simple fix.
manuelesr
Apr 13, 2008 01:08 PM
Rob!
Jan 12, 2005 05:53 PM
Fraggle
Dec 4, 2003 03:10 PM
calcnerd
Sep 24, 2002 08:07 PM
Mike B
Apr 17, 2002 09:36 PM
