engine rev problem on a gsr
Old Jan 11, 2006 | 01:17 PM
b20civicboi's Avatar
Default engine rev problem on a gsr
My friend has a 98 gsr and one night he decided to go out and have a little fun in it. On the way home, he pushed his car at the light and then his car's engine malfunctioned and would not go past 5K.. it just sat there at 5K as if it were redlining.
Does anyone know of why this is happening and how to fix it?
thx guys
Old Jan 11, 2006 | 02:00 PM
nitrofish420's Avatar
Default Re: engine rev problem on a gsr (civicLS97)
What do you mean by "pushed his car at the light"?
Old Jan 11, 2006 | 02:05 PM
Dogginator's Avatar
Daisy... Daisy...
Was the engine warm?
Old Jan 11, 2006 | 03:40 PM
Rcp's Avatar
Rcp
something is stuck in his throttle body..
Old Jan 11, 2006 | 05:43 PM
Default Re: engine rev problem on a gsr (nitrofish420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrofish420 &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by "pushed his car at the light"? </TD></TR></TABLE>
meaning taking off at the light.. everything was fine before hand and it was a big surprise..
the engine was warmed up and have been driven for a while, and the temp guage was averagely in the middle.
I'll look in to checking the throttle body, but if any other possibilities come up, i'm def. up for having them.
what would you mean by something stuck in the throttle body?
thanks
Old Jan 11, 2006 | 06:18 PM
infumis's Avatar
meaning there is something stuck not letting the butterfly spin past a 5K voltage readout so the ecu stops fuel and only lets it sit at 5k....but this wouldnt be the problem if your friend can push the pedal to the floor...check your spark plugs and wires and perhaps your distributor
Old Jan 11, 2006 | 06:20 PM
Dogginator's Avatar
Daisy... Daisy...
Check for CELs. You said that the car seemed like it hit a rev limiter. There may be a problem with the VTEC system.
Typical causes include low oil level, clogged VTEC solenoid screen, VTEC pressure sensor, etc.
Old Jan 12, 2006 | 03:27 PM
Rcp's Avatar
Rcp
well i had a cold air intake awhile back.. and i redlined 1st gear.. then the bypass valve (the rubber part) got sucked into my throttlebody..
it did had sympton's you're listing now..
Old Jan 14, 2006 | 10:29 PM
Default Re: engine rev problem on a gsr (Dogginator)
"Typical causes include low oil level, clogged VTEC solenoid screen, VTEC pressure sensor, etc"
thanks a lot man, yours turned out right.. the oil was low and the oil sensor noticed that and limited it
i appreciate the help guys
mrDalvin
Feb 1, 2007 07:30 AM
luckypon7
Jan 30, 2006 05:19 AM
97LXAcc0rd
Nov 12, 2005 08:15 AM
KetteringITR
Nov 15, 2004 10:03 AM
J MaCk gSR
May 21, 2004 05:26 AM
