help with brake light
Old Jan 9, 2006 | 06:41 AM
nabisco33511's Avatar
Default help with brake light
I have a 01 gsr and I have noticed that my brake light in the dash stays on when I first start up and will stay on, periodically going off sometimes when i apply the brake. After about 20 mins the light seems to go off all together.
So my questions is has this happened to anyone else and is that a warning light?
are my brakes bad?
thanks
Aaron
Old Jan 9, 2006 | 07:21 AM
Abez's Avatar
Default Re: help with brake light (nabisco33511)
check the brake fluid level.
Old Jan 9, 2006 | 07:24 AM
fastrunner's Avatar
Default Re: help with brake light (Abez)
if your brake fulid level is good then check to see if the light goes off if you remove and reattach your brake fluid reservoir cap. If it does the you need a new cap for your reservoir, the sensor in the cap is bad.
Old Jan 9, 2006 | 09:52 AM
thanks guys!
intech
Nov 17, 2005 02:44 PM
Gsrteggrl
Jul 2, 2005 10:06 AM
HardSaltydogg
11
Jun 18, 2005 04:11 PM
zerogravitycrx
Apr 6, 2005 11:29 PM
ITRaholic
Oct 12, 2002 10:22 AM
