Removable ECU?
Old Jan 10, 2006 | 07:41 AM
Solscud007's Avatar
Default Removable ECU?
some one mentioned this on another forum about "repinning the ECU"
re-pin the ECU wiring harness and make a plug-in adapter to pin it back to normal; take THIS with you everywhere (you can take the ECU with you too, or hide it in the car)...if a theif tries to plug in his ECU (they do bring them along sometimes) or your own, he may fry the ECU...but your car is safe. You just need to plug-in that adapter each time. You can re-locate all of this into the glove-box. ----> there is also a company which will do this wiring harness for you (about $125 I think)... Keep in mind any engine management upgrades you may have in the future (wiring purposes)
can some of you explain this I dont get it. thanks
Old Jan 10, 2006 | 08:00 AM
nickG's Avatar
Default Re: Removable ECU? (Solscud007)
sounds like an adaptor that you use to plug in your ecu...then w/o the adaptor, a theif plugs in their own adaptor, and the wires are different and the car doesnt work...
ppl used to take their own ecus out, so theives would bring their own..
Old Jan 10, 2006 | 08:32 AM
Solscud007's Avatar
Default Re: Removable ECU? (nickG)
so where could I get this harness plug adapter?
Old Jan 10, 2006 | 08:36 AM
BlackAckeR's Avatar
http://www.securityadapter.com/store/
Old Jan 10, 2006 | 09:05 AM
Solscud007's Avatar
Default Re: Removable ECU? (BlackAckeR)
thanks,
jsut curious. 94 integs have OBD1 right?
Old Jan 10, 2006 | 10:06 AM
kuja's Avatar
yes.
Old Jan 10, 2006 | 10:58 AM
BlackAckeR's Avatar
Default Re: (Mr One Lane)
98 Spec R posted the original thread in the Type R forum: https://honda-tech.com/zerothread?id=1483794
He does mention a forthcoming ODBI version!
what1118
Dec 15, 2007 07:00 PM
nicko360
Mar 28, 2007 03:59 PM
Civic168
Jul 5, 2006 06:04 PM
the soL that could
Mar 29, 2006 08:33 AM
white_panther
Oct 7, 2005 06:24 AM
