i need help
Old Jan 10, 2006 | 10:40 AM
sixtodc2's Avatar
Default i need help
well i place a ground wire kit for my 01 integra .. i took off the battey so i can connect the wire to the battery,. when i was finish i wanted to listen to the radio and the radio said error .. it like i need a code.. do any of u know the code so i can unlock it ... the only music i can her is my engine,, lol
Old Jan 10, 2006 | 11:22 AM
WhoDoYouThink's Avatar
Default Re: i need help (sixtorice)
look under the fuse box in front of the battery. there is usually a sticker on the bottom of the cover for the fuses and that should have a 6 digit number you enter into the radio.
Old Jan 10, 2006 | 11:26 AM
XYU's Avatar
XYU
Ask me about vaginal warts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000turbogsr &raquo;</TD></TR><TR><TD CLASS="quote">look under the fuse box in front of the battery. there is usually a sticker on the bottom of the cover for the fuses and that should have a 6 digit number you enter into the radio.</TD></TR></TABLE>
or... put some mp3 unit instead
Old Jan 10, 2006 | 12:53 PM
sixtodc2's Avatar
Default Re: i need help (DC4 B20)
NAW MAN I CHECK MAN . THERE AINT **** IN THE FUSE BOX ... SHOULD I CALL THE DEALER AN ASK OR WUT..
Old Jan 10, 2006 | 11:05 PM
ekzrated's Avatar
depends. Your dealer may or may not have the code. How long ago did you buy it from them? and how old is your car. I think they only keep those codes for 5-7 years anymore, but I could be wrong. If you can't find the code, it may be time to upgrade to a decent mp3 player. Good luck-ekzrated
Old Jan 11, 2006 | 06:19 AM
Rikter's Avatar
The only way you are going to get the code is to go to the dealer with your VIN # and proof that you own the car. If they don't have it on file you will have to pull the radio. There should be a stick on the radio that will have a serial #. They can run that # and get a radio code for you.
It's a pain in the *** but if you want it to work that'll be what you have to do. Good luck.
-Rik
P.S. Learn how to spell.. learn how to turn off the Caps-Lock
D831SI
Acura TL, RL & ZDX
Nov 27, 2012 11:57 PM
2Accords
Aug 20, 2011 07:34 PM
ken00si
Oct 25, 2006 12:28 PM
Pete_SI
Jul 30, 2005 05:07 PM
cu3tip
Feb 22, 2004 07:03 PM
