compression specs for a 92 LS
Old Jun 18, 2006 | 06:50 PM
zyntax's Avatar
Default compression specs for a 92 LS
hey, i was wondering if anyone knew what all four cylinders on a 92 LS (B18A1) are supposed to read.
i'm going to run a compression test tommorow and i'd like to see how close to OEM spec i am.
thanks
Old Jun 19, 2006 | 10:11 AM
zyntax's Avatar
Default Re: compression specs for a 92 LS (zyntax)
ttt
someone has got to know
Old Jun 20, 2006 | 09:41 AM
zyntax's Avatar
i've been searchin around the inet and i can't find anything.
anyone have a helms they can read it out of?
Old Jun 20, 2006 | 01:58 PM
Sam92Teg's Avatar
nominal 185 lbs
minimal 135 lbs
max var 28 lbs
Old Jun 21, 2006 | 01:53 AM
zyntax's Avatar
Default Re: compression specs for a 92 LS (Sam92Teg)
thanks, i appreciate it
Old Jun 21, 2006 | 02:17 AM
redDAinteg's Avatar
when I did my compression check about 3-4 months ago, I got about 160-165 all across. im pretty sure a PERFECTLY healthy running LS would pull off 180-190.
Old Jun 25, 2006 | 12:04 PM
zyntax's Avatar
Default Re: compression specs for a 92 LS (redDAinteg)
*update*
i finally got around to doing the compression test and i read a 195 all the way across. seems pretty high, but it is consistant to all 4 cylinders so i'm guessing the engine is healthy.
thanks for the info guys
Old Jun 25, 2006 | 12:05 PM
projectTeG's Avatar
my ls read about 180 across the board when i had it.
reallycooleg
Mar 8, 2006 09:06 PM
CBURKE
Sep 17, 2005 06:17 AM
redDAinteg
May 25, 2005 04:31 PM
B18PoweredCivic
Nov 12, 2004 03:49 PM
