Pulling codes from a 99 integra
Old Jun 14, 2006 | 01:04 PM
IntegraLova's Avatar
Default Pulling codes from a 99 integra
Ok first I would like to say that I have searched and found numerous articles for accord, civic, ect, and cant get it to work.For an accord obd2 it says to use a paper clip on #5 and # 9 holes on the obd2 data port. Then im supposed to count the blinks on the cel light. I cant get this to work.Out of nowhere today i start the car up and theres a cel light.The car doesnt appear to act diffrently though. I really wanna figure this out before I drive the car anymore.I dont have the money to take it somewhere either.If anyone could direct me to a "how to" for an intergra obd2 i would be very gratefull.
Old Jun 14, 2006 | 01:08 PM
DA6righthand's Avatar
Default Re: Pulling codes from a 99 integra (IntegraLova)
on integras, theres a little blue plug that is above the ecu. its a loose end and thats where you put the paperclip
Old Jun 14, 2006 | 01:15 PM
iH8RICERZ's Avatar
two threads you can use...
https://honda-tech.com/zerothread?id=978933
https://honda-tech.com/zerothread/1171263
I think team-integra has a write up..i'll let you know if i find it
Old Jun 14, 2006 | 01:55 PM
Default Re: Pulling codes from a 99 integra (iH8RICERZ)
Ok I found the green housing holding the blue plug.(crammed up in the dash)I end up getting code 90 which according to the threads is Evaporative Emission Control System leak detected in the fuel tank area So where do i go from there?I see all the other pxxxxx codes below them but the only ones i see simular to that are:
P0456 Evaporative Emission (EVAP) System Very Small Leak Detected
P0457 Evaporative Emission (EVAP) System Leak Detected Fuel Fill Cap Loose/Off
P0496 Evaporative Emission (EVAP) System High Purge Flow
P0497 Evaporative Emission (EVAP) System Low Purge Flow
P0498 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit Low Voltage
P0499 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit High Voltage
I took off my fuel cap and retightend it back on. Cel is still on unfortunatley.Now that the easiest is not the problem, where do i go from here?I shouldnt have to reset anything to make the cel go off will I?
truongmai8d
Jul 21, 2011 07:35 PM
dohcrxl
Jan 28, 2006 11:06 AM
96ls
Acura TL, RL & ZDX
Jan 20, 2006 07:27 PM
ViperRedCRX
Dec 4, 2003 04:29 PM
BigChris
Apr 2, 2003 01:32 PM
