rear squirter doesn't work.
Old Jun 15, 2006 | 09:40 AM
mrdeadman's Avatar
They let me pick
Default rear squirter doesn't work.
I need it, because the window always gets dirty. Does anyone know any common causes of this and what should I check? It is annoying that it doesn't work anymore. Thanks.
Old Jun 15, 2006 | 09:47 AM
kchungb17a's Avatar
Default Re: rear squirter doesn't work. (mrdeadman)
Mine stopped working after I left my resevoir empty for way too long. I think minieral build up at the nozzle is the culprit. If the front works and the rear doesn't, you probably have a blockage somewhere, likely at the rear nozzle. You can try to remove it (try pulling while wiggling forward and backeard) and pull the tube off the nozzle and try the rear squirt action (dont' loose the tube inside the roof). If it flows then the nozzle is clogged. You can try to soak it in some hot water for a little bit to see if that clears it up. I've also used some strands of wire to poke through the nozzle holes to clear it. Or you can go buy a new nozzle at the dealer.
good luck
Old Jun 15, 2006 | 10:27 AM
mrdeadman's Avatar
They let me pick
Default Re: rear squirter doesn't work. (kchungb17a)
Thanks man. I went out and jiggled it around a bit and then turned it on and it started coming out slowly, then I kept running it and it cleaned out so now it works again. Thanks.
pnyklr
Jun 24, 2012 11:18 PM
UgP
Jun 16, 2007 10:51 AM
b20acura
Jun 25, 2006 12:45 PM
skribblah
16
Jul 2, 2003 09:47 AM
PnX-R
Feb 9, 2002 09:16 AM
