hid problem
Old Jun 17, 2006 | 09:07 AM
1sikhatch's Avatar
Default hid problem
can someone please help me get these things working. i bought my car with a retrofitted hid kit and one of the bulbs blew so i ordered 2 new ones (9006). so here's the problem the ballast i have has 3 wires (red, green and orange) but the new bulbs only have 2 wires and i cant get them working. the ballast says d2r and i dont know what car they came out from.
Old Jun 18, 2006 | 05:31 AM
EnjoyTheRideDC2's Avatar
Default Re: hid problem (1sikhatch)
Can you post pics of the ballasts?
Sounds like you bought bulbs made for Aftermarket HID Kits and not to the specific ones you have. It would help to see the ballast and connector for the bulb itself
Old Jun 18, 2006 | 10:16 AM
1sikhatch's Avatar
Default Re: hid problem (EnjoyTheRideDC2)
ok here's a pic of the ballast with the plug. u can also see the plugs for the hid's i bought. so aftermarket hid bulbs wont work with the factory kit?
Old Jun 18, 2006 | 11:03 AM
Lauj87's Avatar
well if they were retro fitted you would have to use the bulb of the car that the kit came off of. Not too sure if im right but could be wrong.
Old Jun 18, 2006 | 11:21 AM
Ok Buddy, what you have are the Mitsu or Panasonic OEM Acura HID ballasts, commonly found in TL's and TSX's. I would not advise you to use that bulb with that ballast. I'm sure there's a way to get em powered up, but it would require chopping the OEM bulb connector from your current ballasts. NOT good...
My Advice: Sell the 9006 bulbs you bought, pick up a set of d2r/d2s Philips or Osram 4300K bulbs, and get them rebased to lock in a 9006 headlight housing.
At least this way, it'll plug right into the headlight connector from the ballasts you have now, and will probably be better in color and quality.
Old Jun 18, 2006 | 05:36 PM
1sikhatch's Avatar
too late already cut one harness
Old Jun 18, 2006 | 08:54 PM
silva95teg's Avatar
if they are actually retrofitted they would almost certainly use d2s bulbs, i would be retarded to cut the high voltage leads on the ballasts.
roland021
Lighting
May 7, 2010 09:03 PM
SilverWarrior
Oct 12, 2007 03:03 PM
geminis2k
Nov 4, 2003 12:02 PM
Mr. Choi
Sep 28, 2002 01:30 AM
