Coolant in Cyclinders HOw and why?
Old Jun 17, 2006 | 07:13 PM
Vtecme92's Avatar
Default Coolant in Cyclinders HOw and why?
I have a gsr integra and my car wasn't starting/studdering and I decided to check the spark plugs and ther is tons of coolant in the cylinders? HOw can this be? What can i check...all 4 cylinders are wet from coolant and I mean alot!
Old Jun 17, 2006 | 07:16 PM
Micha's Avatar
FAILWGN
Default Re: Coolant in Cyclinders HOw and why? (Vtecme92)
Sorry man, you have a blown head gasket.
b16adx's Avatar
blown hg more than likely
Old Jun 17, 2006 | 07:40 PM
Vtecme92's Avatar
Default Re: Coolant in Cyclinders HOw and why? (b16adx)
How can I tell if the head gasket is blown or not? I had a new head gasket put in about 1 month ago...I mean not just a little coolant alot!
Old Jun 17, 2006 | 07:46 PM
Uncle Willie's Avatar
Take it back to whoever did it. Hopefully ur valves arent bent.
Old Jun 17, 2006 | 08:11 PM
__oversea's Avatar
Default Re: Coolant in Cyclinders HOw and why? (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">Sorry man, you have a blown head gasket. </TD></TR></TABLE>
Old Jun 17, 2006 | 11:12 PM
b16adx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecme92 &raquo;</TD></TR><TR><TD CLASS="quote">How can I tell if the head gasket is blown or not? I had a new head gasket put in about 1 month ago...I mean not just a little coolant alot!</TD></TR></TABLE>
Whoever did it could have put it on flipped over...ive seen it b4
Old Jun 17, 2006 | 11:39 PM
20geezer00's Avatar
I know that when I put a headgasket on my supra it had to be broken in... I don't know if the integras are like that but I would assume so...
Old Jun 18, 2006 | 07:05 AM
Vtecme92's Avatar
Default Re: (20geezer00)
yes cause it was fine for a while and then it was studdlering, then I check my plugs then they were full of coolant in the cyclinder could I gotten a use head gasket instead of a new one?
Old Jun 18, 2006 | 07:20 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Vtecme92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecme92 &raquo;</TD></TR><TR><TD CLASS="quote">yes cause it was fine for a while and then it was studdlering, then I check my plugs then they were full of coolant in the cyclinder could I gotten a use head gasket instead of a new one?</TD></TR></TABLE>
I hope not. You never reuse a head gasket: once it has been torqued it cannot be reused. You are also supposed to gradually torque the head bolts in a set sequence to properly crush the new head gasket.
Old Jun 18, 2006 | 07:25 AM
96 GSR-T's Avatar
Headgaskets are like condoms.... never re-use them You my friend have a blown head gasket.
Old Jun 18, 2006 | 08:00 AM
akstunt600's Avatar
they also could have routed a water line to a vaccum source. but most likely would shutter and sound like its cammed, and small amounts of steam are visible, but im willing to bet if its alot u have an improperly installed hg or a blown one.
is this motor bored and boosted? if so u could have cracked the sleeves.
Old Jun 18, 2006 | 09:11 AM
Pooby88's Avatar
Default Re: (akstunt600)
A couple ways to detect a blown head gasket: White smoke in exhaust ( if it's real bad). Also open the radiator cap (when car is cold!), then start car. If the gasket is blown, you'll see bubbles/foaming in the coolant. Also check the oil for water/antifreeze contamination.
Old Jun 18, 2006 | 09:30 AM
Bond's Avatar
Default Re: Coolant in Cyclinders HOw and why? (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">Take it back to whoever did it. Hopefully ur valves arent bent. </TD></TR></TABLE>
lol why would his valves bend...it's just a blown headgasket. yeah for sure it's a blown hg. whoever did the work on it didn't do something right. no way a headgasket should blow within a month of being replaced. investigate!
Old Jun 22, 2006 | 04:56 PM
Vtecme92's Avatar
Default Re: Coolant in Cyclinders HOw and why? (Bond)
LOL..I took it to another place! They put in a use head gasket or never replaced the gasket in the first place! I got a new one in and it is back to normal!
VROOOOM..Vrooom! No booost or sleeve block just all motor..thanks guys!
Old Jun 22, 2006 | 05:56 PM
atg1290's Avatar
Those damn ********, you can't trust anyone thats why im hesitant to take it to a shop. Either they lie or beat your car.
Old Jun 29, 2006 | 02:20 PM
CASTUDILLO01's Avatar
SOUNDS LIKE A BLOWN HEAD GASKET, THE PERSON EITHER DIDN'T TORQ THE HEAD RIGHT INSTALLED THE GASKET WRONG. CHECK BY DOING A LEAK DOWN TEST OR COMPRESSION TEST TO SEE WHICH CYLINDER IS BAD. COULD BE THAT THE BLOCK IS CRACK ALSO BUT UNLIKELY BUT POSSIBLE.
Old Jun 29, 2006 | 02:27 PM
zer0bot's Avatar
Default Re: Coolant in Cyclinders HOw and why? (CASTUDILLO01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASTUDILLO01 &raquo;</TD></TR><TR><TD CLASS="quote">SOUNDS LIKE A BLOWN HEAD GASKET, THE PERSON EITHER DIDN'T TORQ THE HEAD RIGHT INSTALLED THE GASKET WRONG. CHECK BY DOING A LEAK DOWN TEST OR COMPRESSION TEST TO SEE WHICH CYLINDER IS BAD. COULD BE THAT THE BLOCK IS CRACK ALSO BUT UNLIKELY BUT POSSIBLE.</TD></TR></TABLE>
Thanks johnny come lately
He got it fixed already and posted about it.
Old Jun 30, 2006 | 02:45 AM
b16adx's Avatar
hahaha damn dude did you not read the thread
efjones9
May 1, 2009 06:48 PM
boostedNOTHARDLY
Dec 4, 2007 07:27 PM
racingfan
Sep 3, 2006 11:27 AM
hb_guy
Oct 29, 2005 06:12 PM
whagkangmakulet
Oct 8, 2001 02:14 PM
