compression test problem - HELP
Hey guys.
Ok well, I took out the spark plug wires and spark plugs, removed the proper fuse. Screwed on the end of the compression tester, did the cranks to get the psi on cylinder one and then went to unscrew the compression tester. One problem, it doesnt wanna unscrew! I only screwed it on hand tight, but now its just about impossible to unscrew off!
Anyone have any advice?
Thanks
Thanks
fakeownzjoo
Sep 21, 2006 04:31 PM
