Distributor bearings?
Old Jun 17, 2006 | 11:05 AM
mike9571's Avatar
Default Distributor bearings?
I have a nasty sound that im pretty sure is coming from the distrib. So my question is does the distrib. even have bearings? If so is it a quick fix?
Old Jun 17, 2006 | 11:38 AM
akstunt600's Avatar
yes, and obd0 dizzys go bad all the time b/c the bearings go and then it self destructs the cpk, cmp, and cyp sensors.
however, obd1 and 2 fail occaisionally as well
Old Jun 17, 2006 | 11:41 AM
mike9571's Avatar
Default Re: (akstunt600)
OBD1 here
Old Jun 17, 2006 | 11:59 AM
akstunt600's Avatar
Default Re: (mike9571)
yeah it could be bearing failure
how bout taking off the dizzy and spinning the shaft that should tell u impeadiately
it should feel smooth but notchy there should be no shaft play
btw when u put the dizzy back on, only one bolt is needed to secure it to the head the bottom one deff. must go as its a pita
Old Jun 17, 2006 | 12:08 PM
mike9571's Avatar
Ok thanks im on my way to the garage now
Old Jun 17, 2006 | 12:57 PM
mike9571's Avatar
Well its off, and the tip of (with the 2 teeth that mate with the camshaft) it is pretty wobbly. When i spin the shaft it wiggles alot is it normal.
Old Jun 17, 2006 | 01:24 PM
akstunt600's Avatar
the base with 2 notches pivots, if u cant determine from that end pull of the cap 3 screws and pull the rotor off one screw, and then check from there if there is any play. and see if there is any noise while spinning the shaft
Old Jun 17, 2006 | 01:28 PM
mike9571's Avatar
I actually took off the the base with to nothches to see if it was oblonged. Its not the bearings either. The shaft it tight and seems fine. Its gotta be the tip its not tight and just wiggles and makes a little chatter when i spin it with my fingers.
With your expieriences with a distrib does the tip with the notches fit tightly or wiggle?
Old Jun 17, 2006 | 03:47 PM
akstunt600's Avatar
the exposed shaft with notches will pivot in 2 directions freely, and it should be smooth but notchy feeling when spun
Old Jun 17, 2006 | 03:55 PM
mike9571's Avatar
It moves enough to make a chatter even with my fingers.
Old Jun 17, 2006 | 04:02 PM
akstunt600's Avatar
as long as its side to side play only from the center of the pivot , that would be normal.
Old Jun 17, 2006 | 04:05 PM
mike9571's Avatar
ok, thanks. Maybe it not the distib after all.
JSpin
Nov 8, 2006 04:45 AM
x00gsr
10
Dec 3, 2004 04:55 PM
Hondasaurs
Aug 4, 2003 01:12 PM
CRX Si
May 3, 2003 02:03 PM
Sir_Phobos
Apr 3, 2003 11:58 AM
