HELP!!! Distributor Problem gone bad
Old Jun 14, 2006 | 02:23 PM
96AcurategGSR's Avatar
Default HELP!!! Distributor Problem gone bad
I posted two weeks ago about my 96 GS-R having a bad distributor and the mechanic's i sent it too asking $800 large for the repair.
my friend had a distributor ordered and installed it. When we went to crank the car, it would not fire, and cranked weak. we nearly cranked battery dead before deciding to check the spark plugs. Checked for spark - no spark. so we Replaced two ignition fuses in the fuse box, first, an all plastic fuse shaped perfectly like a fuse, however no metal inserts (which we think the mechanic who had my car may have put in the box), and another blown ignition fuse. Checked for spark - sparks now but still cranks weakly.
Called the mechanic that had my car for a couple days, he said he thought that the problem was that the car was flooded from over cranking, and he denied knowing about the plastic fuse in the ignition box.
it did smell like gas, so we clear flood mode cranked it for awhile, but that didn't help. same problem, weak crank, won't fire.
just to check, removed head cover, timing belt is still strong.
Any ideas?
Old Jun 14, 2006 | 02:39 PM
qfast817's Avatar
Default Re: HELP!!! Distributor Problem gone bad (96AcurategGSR)
well is the dizzy new, or did you rebuild it?
Old Jun 15, 2006 | 03:21 PM
cleanda6's Avatar
did u have the engine in tdc before u put the distributor and also was the rotor on the right place prior to putting the cap on ??
S2KILLA
Aug 5, 2011 09:30 AM
1badcrx
Jul 26, 2009 10:37 AM
wood 1
12
Sep 24, 2006 01:37 PM
RaCk
14
Jul 17, 2006 08:05 AM
2ndGenGsr
May 18, 2003 01:58 AM
