quick FITV question
Old Jun 16, 2006 | 02:47 PM
saikouEF8's Avatar
Default quick FITV question
i know there countless threads on fixing a bad idle, but im going through all the motions with no luck... im wondering if i just unplugg the fitv and drive around with it like that, will something bad happen? my car has a pulsating idle nomatter what i seem to do. ive tried everything and the only way it idles good is with that thing unplugged.
Old Jun 16, 2006 | 03:28 PM
saikouEF8's Avatar
Default Re: quick FITV question (saikouEF8)
YO!
Old Jun 16, 2006 | 05:28 PM
saikouEF8's Avatar
Old Jun 16, 2006 | 05:37 PM
JDM_DC4_Fanatic's Avatar
Check timing, fuel pressure, vacume and make sure that all your plugs and wires are tight and in good shape.
Timing -> verify that the timing is within spec
Check fuel pressure -> proper fuel pressure is read at the fuel rail, not the filter
Check Injector pulse -> take it to a mechanic...unless you have a Noid light set
Vacume -> make sure all your vacume lines are crack free!
MAS Sensor -> make sure that your Mass Airflow Sensor is working properly
There are many things that cause bad idel...you gotta eliminate them 1 at a time bro
Old Jun 16, 2006 | 05:47 PM
This may help even more then I did originally...
I found this old post
https://honda-tech.com/zerothread?id=699787
that should do the trick
knuxx
10
Dec 19, 2011 04:10 PM
HyperFlow
May 15, 2010 06:28 PM
slikz714
Feb 26, 2010 11:37 AM
trrbl1bmx
Sep 15, 2007 07:22 PM
dragaholic
Feb 23, 2007 11:05 PM
