Low Idle
Old Jun 18, 2006 | 02:19 AM
leshok's Avatar
Default Low Idle
Last week I replaced the valves in the head (shifted into 2nd insted of 4th to make a long story short). After having everything bolted up I slipped on the timing belt and let the car warm up to operating temp. Then I proceded to time into to time it just as it calls for in the book. But now I noticed the Idle will stay consistantly low (about 500-550rpms) This is defiently too low for a 95 B18c engine. Do you guys have any Idea what could be causing this?Everything has been gone over at least twice. If I can figure this out it would help with a lot of headaches!! Thanks in advance.
Old Jun 18, 2006 | 02:25 AM
Leo C's Avatar
Night Owl
Default Re: Low Idle (leshok)
adjust your IACV
Old Jun 18, 2006 | 02:26 AM
Leo C's Avatar
Night Owl
it should be at 700-800.
Old Jun 18, 2006 | 03:14 PM
leshok's Avatar
I will try that out...thanks!
Old Jun 18, 2006 | 03:15 PM
Leo C's Avatar
Night Owl
Default Re: (leshok)
Old Jun 18, 2006 | 05:54 PM
leshok's Avatar
That is a no go....the idle is stiill low. Around 500rpms. Any other Ideas? Vacum leaks? It runs strong throughout the rev range. It just wont idle normal.
Old Aug 8, 2006 | 09:47 AM
turboxsi's Avatar
I know this is a dead thread but i have the same issue with my 94 Cx w/ a b16a swap. Any help would be appreciated.
Old Aug 8, 2006 | 10:22 AM
Smog09's Avatar
Default Re: Low Idle (shutupnskate)
Try adjusting the screw on the Throttle Body. You could also check your timing, some cases if the timing is advanced the rpms are elevated.
Old Aug 8, 2006 | 07:38 PM
red01teg's Avatar
Check ur timing definitely. I had a similar problem with my teg. Is your check engine light on?
Old Aug 8, 2006 | 08:23 PM
Danziver's Avatar
Did you adjust you valves properly?
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
frankyp
Feb 6, 2008 07:25 PM
ex94vtec
14
May 6, 2006 02:07 AM
vti-R
Jun 21, 2002 08:01 PM
