95 integra
Old Jun 14, 2006 | 09:57 AM
soon2bdropped's Avatar
Default 95 integra
hi i have a 95 integra ls coupe with 238xxx miles on it... stock engine, clutch and everything.. theres oil leakin from the valve cover and whatnot.. there is coolant lose.. i have no idea.. but i spotted one spot from the upper rad hose that goes into the engine block/head.. anyways today when i start the car up i see blue smoke. not dark dark dark blue.. but light blue.. i was like shitt.. thats a bad sign.. than i rev it up to like 5-6k and u couldn't see anymore smoke.. thats wierd after i rev it up like that.. the rpm kept fluctating from 1500rpm -1700rpm constantly for like 30secs and than back to idle... it idles fine.. the other day i had to do a roll starting. do u guys think its the unburnt fuel left in the cat doing that..
for some reason it doesn;t do this all the time just today.. oh well i plan on rebuilding this LS engine once i go to UTI next year and prepare it to be boost'd when i hit the hotrod and performance class at UTI..
thanks for any tips guys
Old Jun 14, 2006 | 10:19 AM
iH8RICERZ's Avatar
Default Re: 95 integra (soon2bdropped)
when was the last time all the maintenance was done? belts, fluides, hoses, etc?
Old Jun 14, 2006 | 11:23 AM
Leo C's Avatar
Night Owl
a weird idle like that could be a bad o2 sensor. get a tuneup done and an oil change. and flush your radiator
Old Jun 14, 2006 | 11:27 AM
Vitesse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">hi i have a 95 integra ls coupe with 238xxx miles on it... stock engine, clutch and everything.. theres oil leakin from the valve cover and whatnot.. there is coolant lose.. i have no idea.. but i spotted one spot from the upper rad hose that goes into the engine block/head.. anyways today when i start the car up i see blue smoke. not dark dark dark blue.. but light blue.. i was like shitt.. thats a bad sign.. than i rev it up to like 5-6k and u couldn't see anymore smoke.. thats wierd after i rev it up like that.. the rpm kept fluctating from 1500rpm -1700rpm constantly for like 30secs and than back to idle... it idles fine.. the other day i had to do a roll starting. do u guys think its the unburnt fuel left in the cat doing that..
thanks for any tips guys</TD></TR></TABLE>
Do a basic tune up, clean the motor then check for leaks, it's either the O2 sensor.. even try cleaning out your PCV too..
Old Jun 14, 2006 | 01:35 PM
Default Re: 95 integra (beoneightbe)
tune up was done last summer so a year ago from today.. timing belt, spark plugs, axles, waterpump.. only theromstat wasn;t changed..
idunno it stopped smoking.. i'mma try and start it up tommorrow and see if i get blue smoke..
like i said i don't get any CEL lights so? plus the fluctating only lasted like 10secs.. probably because i was stomping on the gas to see if any more blue smoke comes out while engine was still cold...
Old Jun 14, 2006 | 01:44 PM
Wayne_Curr's Avatar
start by replacing your thermostat, that can cause the idle fluctuation. You're topped off on coolant right?
Naazel Sirez
Sep 27, 2018 03:17 AM
Mr_B18C1
May 21, 2011 08:52 PM
raneysjdmdc
Mar 3, 2010 10:45 AM
aleks77
Oct 16, 2008 05:57 PM
-HONDA-
Oct 2, 2007 09:01 AM
