TPS question..
Old Jun 16, 2006 | 02:57 PM
jman86's Avatar
Default TPS question..
I have a 96'LS with intake, intake manifold, catback, and im running a 100 shot of nitrous...my car is idleing a lil high..ive checked multiple times and had other people check for vacume leaks and cant find any...i tested the TPS and the voltage that i got when the throttle was closed was .72v, i know that the tps is supposed to read .5v..would that much of a difference make my car idle at about 1500 rmp?
Old Jun 17, 2006 | 08:36 AM
ckyguy's Avatar
At idle the TPS should be between .2 and 1.4v, at WOT it should be 4.8v, when you move the throttle slowly the voltage should go up smoothly and evenly, you could check to see if it's doing that, but by what you listed and are describing it seems ok.
You could also try unplugging your IAC valve and see if the idle drops to around 500rpms or so, if it does then replace your IAC valve, if it doesn't, that's not your problem.
protopro88
Apr 8, 2011 03:41 PM
jdmboy94
Oct 12, 2009 12:33 PM
zero-one
Feb 14, 2008 04:20 PM
EMphaticONE
Jun 25, 2005 06:26 PM
caLiH22A
Aug 24, 2004 08:05 PM
