Automatic trans upgrades.
Old Jun 18, 2006 | 07:13 PM
silentdeath12886's Avatar
Default Automatic trans upgrades.
i know im a lazy *** for having an auto but will do the auto to manual conversion for when i get a turbo for my ls which will be some time from now. but for right now i want to upgrade my auto so i can put some basics in...i heard of doing the torque converter upgrade, what else can i do? i heard someone mentioning something about the main valve body?
Old Jun 19, 2006 | 06:28 AM
ND40oz's Avatar
Default Re: Automatic trans upgrades. (silentdeath12886)
It's going to cost some good money to get anything done, unless you're willing to do it yourself. The torque convertor will be the easiest, because you don't have to tear your entire tranny apart like you would for a valve body. Basically, when you change the stall in your torque convertor, your tranny doesn't start spinning at a 1 to 1 ratio with the engine until you hit that stall speed. Meaning, you won't start putting power to the wheels until your at a higher rpm. I'm not sure what the stock stall speed is on an LS tranny but you can probably go atleast 1000 rpm if not more and stay streetable.
I'm not sure what a place would charge to do the upgrades, in my durango it was around $2800 not including core for built tranny (valve body, hardened gears) and a 2800 stall.
MetallicaMan
Oct 11, 2004 02:54 AM
ferio 95
Oct 25, 2003 11:05 PM
gearhead18
Apr 30, 2003 07:14 PM
LStech
Apr 4, 2003 12:26 PM
97 teg
Dec 29, 2001 04:38 AM
