Overheating issue
Old Jun 18, 2006 | 01:58 PM
Civicracer17's Avatar
Default Overheating issue
Ok I went for a drive the other day and noticed my car was overheating. So I decided to drive back home. I opened the Hood and there was Coolant coming out of the top of the Resivoir. Also the Top hose of the Radiator was leaking fluid out of it like there was really bad back pressure. Any one have a clue why it would do that?
Old Jun 18, 2006 | 02:18 PM
gsr dood's Avatar
Default Re: Overheating issue (Civicracer17)
most likely ur thermostat closed on you. if the top hose is hot and the bottom hose is cold then u know its only a 7$ for the thermostat and gasket. good luck
Old Jun 18, 2006 | 03:25 PM
Default Re: Overheating issue (gsr dood)
The Upper hose it REALLY hot and the lower hose and hot but not hot as the upper one
Old Jun 18, 2006 | 03:30 PM
akstunt600's Avatar
there u go, it could also be be your thermo switch aka fan switch. heard your fans lately?
Old Jun 18, 2006 | 03:52 PM
Default Re: (akstunt600)
only one goes on after the car has been running alot... they dont come on when driving
Old Jun 18, 2006 | 04:26 PM
akstunt600's Avatar
deffinately thermostat
Old Jun 22, 2006 | 04:01 PM
Ok So I replaced the Radiator and the Thermostat today... Let the Car Run for 5 minutes and the Temp goes Up to H... The Upper hose is HOT and the lower hose is Cool... Is this a bad thermostat or is the system clogged???
Old Jun 22, 2006 | 04:09 PM
__oversea's Avatar
Default Re: (Civicracer17)
you just replaced Thermostat. i bet you mixed 50/50. hmm..does fan comes on?
Old Jun 22, 2006 | 04:15 PM
Default Re: (Last For One)
nope fans dont come on
Old Jun 22, 2006 | 06:40 PM
bump
Old Jun 23, 2006 | 03:05 AM
need help guys
Old Jun 23, 2006 | 03:50 AM
TEGGRY's Avatar
you probably have air inside your hoses, your suppose to put coolant (i used water) inside your new radiator until it fills to the top and make sure your resevoir is filled to its max level marking, doing this will make sure that all the air that went inside your hose gets out of the radiator, you will know that you have bubbles coming out when you pour water or coolant inside your radiator, once your resevoir and radiator is filled with coolant or water turn on your car and let it run you will notice that both of your hoses and radiator should be hot and you will notice that your temperature went down, if not all the way to the cold mark
GOOD LUCK!
dbailey
11
Jan 30, 2020 04:27 AM
xolk88
10
Mar 18, 2010 05:18 AM
jwlee7ucla
Aug 23, 2007 11:41 PM
jwlee7ucla
Aug 7, 2007 03:48 PM
silvsrt4
Oct 1, 2005 11:23 PM
