Pistons/Comp/Fuel?!...
Old Jun 17, 2006 | 10:50 AM
VTECth1s's Avatar
Default Pistons/Comp/Fuel?!...
Putting standard sized CTR or ITR pistons into my GSR, will i need to bring the compression down to run on 91 oct? And if so how would i do that and where would the compression be at?, its a daily driver car, and its not practical for me to run on anything higher. It aint no race car, but still want some kick. Thanks!
Old Jun 17, 2006 | 12:06 PM
92DAIntegraXSI's Avatar
Default Re: Pistons/Comp/Fuel?!... (egg6vtak)
well if your going to put CTR or ITR pistons in your going to raise your compression. a few other thing to look at is a fuel pressure regulater and gauge always should be using 91 or higher octane in a vtec motor. you cant change the compression once everything is together, you will also have to mess with your timing so you wont ping. try searching.
Old Jun 17, 2006 | 04:02 PM
dohcMONSTER's Avatar
Default Re: Pistons/Comp/Fuel?!... (92DAIntegraXSI)
im running 13:1 comp on 91 pump gas, its all in the tuning and build
Old Jun 17, 2006 | 05:04 PM
VTECth1s's Avatar
ill have the fpr, fuel rail, fuel pump, injectors and all that upgraded, i assume after the pistons are put in, i gotta get it tuned asap to see what type of fuel i should be running? I had my share of built motors, just my first time with a GSR now, instead of LS/VTEC from before.
Suck my DX
10
Dec 28, 2006 06:30 PM
kidd_drastic
Nov 26, 2005 11:53 AM
phantom_sol
Jan 22, 2004 11:50 PM
sshaikh01
Feb 6, 2003 02:45 PM
CX-R
Dec 27, 2002 07:06 PM
