spark problem
Old Jan 30, 2008 | 05:38 AM
wiseguyoncouch's Avatar
Default spark problem
I just finished rebuilding a b18c1 and everything is in check I have fuel and it's in time, but spark on only one cylinder and last nite before I went to bed I had two sparking...so my question is what all and how I should test to figure out where the problem is the coil, distributor, wires, cap, plugs?
Old Jan 30, 2008 | 06:25 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: spark problem (wiseguyoncouch)
Step 1: Check the cap and rotor for excessive wear.
Step 2: Obtain a helms/chilton/any other manual and it will tell you what specs your coil and ignitor should be at so you can see if those are bad.
Step 3: Make sure your sparkplug wires are in good condition. (no burn marks or cracks etc...)
By then hopefully you find the problem.
Old Jan 30, 2008 | 07:01 AM
Default Re: spark problem (St Jimmy)
well the cap and rotor and wires are practically brand new b/c they were replaced maybe 4 months before I rebuilt the motor and I know they show no signs of excessive wear, but in all honesty if i have spark on one then the internal coil of the distributor should be good correct? So it's really possible that it's the cap, rotor, or wires...
Old Jan 30, 2008 | 09:47 AM
Blahblah718293's Avatar
most likely, but not definetly. easy stuff first.
W95civicEXcoupe
Other Make Vehicles
Mar 10, 2016 03:26 PM
motoxxxman
May 1, 2015 09:00 AM
sodacan33
Jun 17, 2004 06:53 PM
Kamin
Jul 31, 2003 07:45 AM
