idling problem
Old Feb 2, 2008 | 12:55 PM
datnewhondaguy's Avatar
Default idling problem
i have a issue i just got a integra and the car is idling really high it idle at 2000rpm even when the car is warm what seem to be my problem?
Old Feb 2, 2008 | 01:03 PM
DrGrEeNtHuMb's Avatar
Try adjusting your idle control screw on your throttle body, if that doesnt do it then you probably a vacuum leak. Check all your vacuum hose, replace old nasty ones, and if that isnt it try take a squirt bottle with water, and spray it where the intake manifold meets with the head, and around the throttle body. Your car should bog down a little, whereever it starts to bog, theres your leak. If that doesnt do it, try messing with your timing and your distributor. Good luck!
Old Feb 3, 2008 | 06:59 AM
billabong's Avatar
Default Re: idling problem (datnewhondaguy)
or u can try to play around with the posisioning on the distributer car u can retard it a lil and it shud bring the rpms down a bit
DeCoY
Apr 3, 2007 03:07 PM
f22abuilder
Feb 7, 2006 09:29 AM
del soler
Sep 10, 2004 02:06 PM
Peter Langly
16
Jun 29, 2004 12:30 PM
Norcalstoppy
Jul 30, 2002 06:01 AM
