da problem.
Old Jan 31, 2008 | 04:39 PM
92 CiviC H.B's Avatar
Default da problem.
my car revs from about 900k to about 2200k alone. my ecu was throwing a code 3 map sensor,so i changed that and it still does the same,tps sensor has been replaced,distributor and alternator..does anyone know what could cause this??
car is a 91 integra if that helps.
here is a video of what is happening.
http://youtube.com/watch?v=pnzuCBhxDF0
http://youtube.com/watch?v=pYsE8r9gx8c
Modified by 92 CiviC H.B at 7:34 PM 2/7/2008
Old Jan 31, 2008 | 04:47 PM
DA_9's Avatar
Default Re: da problem. (92 CiviC H.B)
Um, Vacuum leak?
Old Jan 31, 2008 | 05:51 PM
Default Re: da problem. (DA_9)
i don't think its that all my vacuum hoses are connected.
does anyone have a picture of where all the vacuum lines go and how they are supposed to be connected? my map sensor is connect differently then on my brothers teg when i connect it the same way his is the car idles very low and starts to boggg.
Old Jan 31, 2008 | 06:02 PM
db1_jdm's Avatar
There you go brotha! Good luck!
Old Jan 31, 2008 | 06:34 PM
Default Re: da problem. (db1_jdm)
thats how my map sensor is connected. is that the correct way?
Old Jan 31, 2008 | 06:42 PM
db1_jdm's Avatar
no its not, look at the diagram i posted
Old Jan 31, 2008 | 07:09 PM
what gsr's Avatar
^ yeah i don't think thats correct.. try that diagram db1posted.. if that doesn't work.. your air idle control valve should be replaced. thats what was wrong with mine.. i had pretty much the same problem.
Old Jan 31, 2008 | 07:49 PM
phoenixyellowda9's Avatar
did you reset the ecu after changing the map sensor?
Old Jan 31, 2008 | 07:55 PM
Default Re: da problem. (phoenixyellowda9)
yeah i did reset it..i changed the ecu too.
Old Jan 31, 2008 | 08:00 PM
try this if this dosent work then im cluleess https://honda-tech.com/zerothread?id=1844067
Old Feb 1, 2008 | 04:43 PM
JDM92da6's Avatar
dude,if ur car is reving to 2500k ur lucky all u have is an engine light,damn,what setup are u running?
Old Feb 1, 2008 | 05:13 PM
Default Re: (JDM92da6)
nothing special..aem intake and exhaust.
Old Feb 7, 2008 | 06:34 PM
Default Re: (92 CiviC H.B)
video posted.
Old Feb 7, 2008 | 11:58 PM
93vintageGSR's Avatar
Tried swapping out the IAC valve on the back of the intake manifold? They tend to get stuck and will make the idle lope. Easy to bypass if you don't want to replace. Possibly not directly related to trouble code, however.
Old Feb 8, 2008 | 08:40 PM
Default Re: da problem. (93vintageGSR)
i am about to replace it soon to see if thats the problem.
Old Mar 3, 2008 | 08:22 PM
jdmlseg's Avatar
is there any way you could send me pictures of all the vacum hoses and the map sensor?? am having problems connecting it....my car idles a lot...i put a ls on a eg
Old Mar 3, 2008 | 08:38 PM
g2daturbo's Avatar
Default Re: da problem. (jdmlseg)
i will post pics tomorrow when i can get some pics ive also had bad throttle body gaskets do the same thing try it out for a few dollars at the parts store.... u could also get a can of carb clean and spray for vacuum leaks around tb and intake.... let me know how u make out ...w ill try to post pics asap
Old Mar 3, 2008 | 08:39 PM
jdmlseg's Avatar
how do the vacum hoses connect..i have a eg and i put a ls on it.....it idles a lot...i need to know where the map sensor and all the vacum hoses go to..
98bucket
Aug 20, 2013 08:46 PM
pepetype
Feb 3, 2011 08:57 PM
ssergio86
Oct 14, 2010 07:14 AM
DAMCOOLDAV
Sep 12, 2003 02:05 PM
89hb
Jan 6, 2003 06:11 AM
