1990 teggy, rhd conversion, 98 ls, not starting?
Ok..I got a 90 da rhd conversion done, motor is a 98 ls, all converted to obd1a..I'm having starting problems. Car doesn't want to crank over. Im not getting fuel or spark, so far I replaced the main relay twice and no go, any idea's?
Re: 1990 teggy, rhd conversion, 98 ls, not starting? (N. Part 2!)
Listen for your fuel pump, turn the the key over but not completely so your car is not on, you will hear the pump. Are any check engine lights on, can you find the codes and help us help you. Also, check your starter, hit it with a hard metal object see if it's your starter. How many miles on your car, we need to know the condition of your car to help you out. Pull your sparks look at them tell us what you see, you can tell alot about the car by the sparks, do they have oil on them?
