Need some help
Old Feb 2, 2008 | 10:44 AM
808cuban's Avatar
Default Need some help
im going to change the timing belt and water pump this weekend. i was wondering what type of sealer should i use for the o ring on the water pump?
i have turbo cam and cam gears and i dont know how the hell to tell where TDC is on them. too many expletiveing numbers and ****. i was wondering if i just find the TDC on the block, can i just mark the cam gears and then just change the belt.
i dont know im just nervous about getting the timing off. here in hawaii **** is expensive
Old Feb 2, 2008 | 02:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Need some help (808cuban)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808cuban &raquo;</TD></TR><TR><TD CLASS="quote">im going to change the timing belt and water pump this weekend. i was wondering what type of sealer should i use for the o ring on the water pump?</TD></TR></TABLE>
I use none. The o-ring will seal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808cuban &raquo;</TD></TR><TR><TD CLASS="quote">i have turbo cam and cam gears and i dont know how the hell to tell where TDC is on them. too many expletiveing numbers and ****. i was wondering if i just find the TDC on the block, can i just mark the cam gears and then just change the belt.
i dont know im just nervous about getting the timing off. here in hawaii **** is expensive</TD></TR></TABLE>
You can find TDC using the crank pully. There is a catch: TDC on the crank could be 180 degrees out for the cams. Make sure that the rockers for cylinder 1 are closed. The cam gears should be pointing up.
You case may be different, but check this link:
http://www.c-speedracing.com/h...t.php
Old Feb 2, 2008 | 03:52 PM
Blahblah718293's Avatar
Default Re: Need some help (Dogginator)
if you can use a vicegrip or somthing to lock the cams in place when you take the old one off, it should be alot easier to get it back on. other than that idk.
lsdb1
May 10, 2009 01:12 PM
EGCivicChicago
17
Jan 21, 2007 06:45 AM
B18Redline
Nov 6, 2004 10:26 AM
1998hondaaccord
Sep 18, 2003 05:00 PM
Chairman Kaga
Nov 13, 2001 05:06 AM
