Roaring idle + Overheating in 40*F Help!
Never had this problem happen before until about an hour ago. Got into my car and noticed the idle at 3000RPM for about 5 minutes then it would constantly jump from 1000RPM to 3000RPM. The car would, in about another 5 minutes, overheat past the gauge. After I parked, I also noticed all my coolant on the ground.
The strange thing though, while it would overheat I tried to turn the heater on but it would blow ice cold even though my car doesn't have A/C and the heat was all the way up.
Any suggestions?
Any suggestions?
I'm Huge In Japan
Your thermostat can go bad at any time. But the heater would be hot even if your thermostat was bad, which indicates you have no coolant, and... well that's your problem. Find the leak, fix it, and fill it back up with coolant.
Just make sure to bleed out the bubbles in the coolant through the bleeder valve after you fix it.
1) There is air in the heater core.
2) The heater core is clogged.
blue89hatch
08-12-2008 07:57 AM
homeskillet
12-24-2004 09:22 PM
