O2 Simulator
Old Nov 19, 2008 | 06:45 AM
Jayman_Gsr's Avatar
Icon2 O2 Simulator
Im about to turbo my 97 GSR and I was looking at schematics for a o2 simulator so I could fool the OBD2 ecu in to thinking that I had a Cat. I want to run a full 3" exhaust with a "Test Pipe". I would still have the second O2 for visual purposes but I would have this "o2 Simulator" interfaced with the signal wire. My question to you would be is this possible and am I on to something for all those going through emissions? Once again I would NOT have a Cat. just a Test pipe and this electronic device to simulate the o2 voltages that the ecu would be looking for?
Here is the site I came across: http://www.mkiv.com/techarticles/oxy...sor_simulator/
It looks simple enough and the parts are available at radioshack.
Old Nov 19, 2008 | 06:59 AM
Speed94's Avatar
I remember someone else selling an O2 simulator for around 20 or so...
Old Nov 19, 2008 | 07:02 AM
Jayman_Gsr's Avatar
So It will work? Im not trying to buy one I want to make it so I can run a test pipe on my emissions controlled vehicle
Old Nov 19, 2008 | 07:06 AM
Speed94's Avatar
Well I tried 2 different ones...a mechanical one and an electronic one. Both didnt work
Old Nov 19, 2008 | 07:15 AM
Jayman_Gsr's Avatar
oh ok Ill guess ill still give it a try and let you know the outcome...hell itll still be fun to make :D
Old Nov 19, 2008 | 08:22 AM
qazaq's Avatar
i'v tried to put together that same exact simulator, its nothing but a 555 timer which works like a turn signal relay it flips on off small voltage signal that supposed to work. i tested it on my friends rsx where we tried to simulate a signal so check engine light would go off since his header removes a cat. he still has the secondary sensor attached to the header but when we attached that simulator instead of reading of oxygen sensor different cel came up saying that heat sensor error. heat sensor does not match the reading of oxygen sensor
next thing to try is a spark plug extension, but im not sure if it will help your situation
Old Nov 20, 2008 | 05:22 AM
Speed94's Avatar
Spark plug non-fouler...the "extension", is the mechanical one I used. It didnt work. Still threw a code. The o2 sim I got from a website was spliced inline to the sensor wires didnt work either. I never checked which code it was. I was just looking to see if it would throw a code and it did.
RSant
Oct 25, 2006 01:09 PM
IntegraCF21
Sep 24, 2005 04:42 AM
ludermark
Sep 15, 2004 02:20 PM
Nfurno
Feb 4, 2002 06:24 PM
