WINDOW PROBLEM
Old Nov 18, 2008 | 07:24 PM
EGKREW's Avatar
Default WINDOW PROBLEM
i have a 95 integra and the passenger side window wont roll down are up. what could be the problem? HELP ME OUT
Old Nov 18, 2008 | 07:28 PM
EGKREW's Avatar
help me out
Old Nov 19, 2008 | 12:25 AM
subway's Avatar
Power windows? you should check the window motor.
Old Nov 19, 2008 | 01:18 AM
KILLAB17VTEC's Avatar
Genetically Gay
when u roll it up?can u hear the motor whinin?try to roll up/down both side window.if nothing then replace motor.if u hear it,something is loose and need window adjustments or check fuse?
Old Nov 19, 2008 | 07:51 AM
ptown909's Avatar
you need a window motor
it happend to me
Old Nov 19, 2008 | 09:44 AM
KeithsDAteg's Avatar
Judging by your mad typing skills... Your window wont roll up or down.
I always check the easy things first. Check fuses, the switch, then check the motor.
Wouldn't you hate to replace your motor only to put all back together and it still not work because you have a blown fuse or a bad switch.
Old Nov 20, 2008 | 08:33 AM
EGKREW's Avatar
i dont here no motor. i got to change that. thanks. where is the motor located?
Old Nov 20, 2008 | 08:42 AM
mani_0130's Avatar
you have to take the door panel off and you will see it should be by one of the rails, it is usually held on by 3 or 4 screws. Remove the screws, and take the motor out unplug it and plug the new one in then bolt it on, it may take a while to get the window back on track if it moves, make sure to see if it works before you but the door panel back on, if the motor still doesn't do anything then i would check the actual switch but most likely it is your motor.
Old Nov 20, 2008 | 10:06 AM
So, since you cant "hear" the motor moving or trying to move, you are immedialty going to change it out...
Re-read my reply to your first post.
Like I said it could be the switch or possibly the fuse. Have you checked any of that? Before you go ripping your door panel off and dropping $80+ on a new motor I would do some troubleshooting.
Just my .02
Keith
heavenlypeace
Jul 31, 2017 03:10 PM
theazndog
Jun 12, 2009 12:05 PM
ylfotevoli
Oct 27, 2006 12:55 PM
2000civicsi
Oct 29, 2005 04:43 PM
