weird problem, lost speedo AND vtec at same time
Old Nov 15, 2008 | 05:42 PM
bigdogadam's Avatar
Default weird problem, lost speedo AND vtec at same time
so i have a 97 jdm type r swap in a 97 integra with all the corresponding jdm ecu and wiring. all done correctly. it has ran perfect for over a year now. today i was driving a little spirited and banged second gear. immediately the speedo went nuts. so i thought no big deal i have another speedo sensor in my garage off a old tranny. then i went to climb in the higher rpms and realized vtec wouldn't engage. this has me a little stumped and i can't run my scan tool on it because it wont read the jdm ecu. anyone seen anything like this happen before. i haven't had a chance to replace the speedo sensor because its already dark out. i'm really hoping that the ecu isn't screwing up
Old Nov 15, 2008 | 06:01 PM
Jimmy's Avatar
Global Moderator
Take a look at the connector for the VSS plug.. sometimes one of the prong bends or from corrosion breaks off..
Old Nov 15, 2008 | 06:13 PM
bigdogadam's Avatar
Default Re: (Jimmy)
do you think this would cause the vtec engagement issue as well?
Old Nov 15, 2008 | 07:12 PM
majinsoftware's Avatar
vtec only engages if
temp warmed up
speed over 20ks
no cels detected
oil pressure(only on some)
So if your speed wasnt reading correctly or you had a cel this would stop vtec.
Old Nov 16, 2008 | 04:30 AM
bigdogadam's Avatar
Default Re: (majinsoftware)
cool so most likely it is the speedo sensor, i didn't realize it would trip a CEL cause i have my bulb unhooked
Old Nov 16, 2008 | 04:58 AM
bunnyhatch93's Avatar
Default Re: (bigdogadam)
yea if you vss goes by by youll have no vtec
Old Nov 16, 2008 | 06:02 AM
bigdogadam's Avatar
Default Re: (bunnyhatch93)
thanks i appreciate all the input
stehigs321
15
Mar 1, 2019 05:16 PM
fyah2k5
Aug 25, 2014 11:19 AM
EKhothatch
Sep 2, 2005 09:08 AM
B16 CRX
64
Jul 23, 2004 10:06 AM
B18C-Hatch
Aug 31, 2002 02:04 PM
