help with distributor!!
Old Nov 19, 2008 | 03:15 PM
hondakrazy's Avatar
Default help with distributor!!
So i have kind of a weird issue. I have an ls/vtec swap in my teg. Recently my car would sputter when I initially hit the throttle. The next day my wife drove the car and she called me to tell me that the car wouldn't rev past 3,500 rpm's. I test drove the car when she got home and and heard a weird knocking noise. I realized that it was my distributor. The inside off the distributor was all f*cked up. So I went to replace it with another ls dizzy. The car didnt want to start...... to get to the point I went bout ght what I thought was a b16 dizzy and it ended up being for a d16. But after trying numerous distributors the only one that will run my car is the one from the single.....Any suggestions?
Old Nov 19, 2008 | 03:43 PM
b18c1ej8's Avatar
wires, plugs, cap,rotor, dizzy
Old Nov 19, 2008 | 03:50 PM
hondakrazy's Avatar
all new but the only dizzy that works is the one from the single
Old Nov 19, 2008 | 04:28 PM
hondakrazy's Avatar
nobody has any ideas
Old Nov 19, 2008 | 04:59 PM
slaminsam's Avatar
So the first dizzy you bought didnt want to run? I had that problem before and it turned out to be a bad new one... I am pretty sure that all of the obd1 dizzies internals are swappable if I remember correctly... I may be wrong though...
Old Nov 19, 2008 | 05:09 PM
hondakrazy's Avatar
i tried more than one. i tried an ls one then the one for the single, then a b16 dizzy. the only one that worked was the one for the single...
Old Nov 19, 2008 | 05:14 PM
slaminsam's Avatar
How is it running with the single slam one? If it runs great then I wouldnt worry about it. We are talking about a 95 db7 aren't we?
Old Nov 19, 2008 | 05:46 PM
hondakrazy's Avatar
yea its a db7. but it doesnt run good. it sputters and is extremely slow.
Old Nov 19, 2008 | 06:04 PM
slaminsam's Avatar
I would check the timing and make sure it hasn't jumped or anything.
Old Nov 19, 2008 | 06:08 PM
hondakrazy's Avatar
alright ill do that and then ill update
Old Nov 19, 2008 | 07:50 PM
SlammedDC2's Avatar
Semper Fidelis
Seeing as how the d16 distributor isn't made to run a b series ls/v why don't you try out a gsr distributor? IIRC all obd1 b series dizzy's are the same, but it couldn't hurt to try one more made for the motor.
just my 0.02
Old Nov 20, 2008 | 01:40 PM
hondakrazy's Avatar
ive tried them all except for the gsr one. i was runnig it b4 with an ls dizzy
Old Nov 20, 2008 | 02:27 PM
hondakrazy's Avatar
does anyone else have any thoughts on what it could be?
Old Nov 20, 2008 | 07:48 PM
DEEABLO's Avatar
how about a picture of it
Old Nov 21, 2008 | 02:15 PM
hondakrazy's Avatar
a pic of the dizzy?
Old Nov 23, 2008 | 04:36 PM
gsrstick's Avatar
try drilling small hole to let charged air escape. just a thought ,have to do it with my msd.
Jhicks
Jan 28, 2012 07:08 PM
Civic483973
Jul 26, 2010 10:22 AM
hondakrazy
Feb 20, 2009 02:31 PM
