The Hood?
Old Nov 19, 2008 | 06:27 AM
SydneyLS's Avatar
Default The Hood?
Does the hood make a difference in performance? Being a scoop or a cowl?
Old Nov 19, 2008 | 06:29 AM
4g63powered's Avatar
Considering where the intake is, no.
You *might* see a drop of 0.04sec off your 0-60 from a lighter CF hood.
But no; hoods are cosmetic mods.
Old Nov 19, 2008 | 08:28 PM
shy_lee85's Avatar
your car will FLY.. add a 3 layer wing too..
Old Nov 19, 2008 | 08:36 PM
SlammedDC2's Avatar
Semper Fidelis
If you don't have anything productive to say keep your thoughts to yourself.
OP no a scoop isn't going to help you. As for weight reduction and track times. Every 100 pounds you loose, you gain 1/10th of a second. Loose 500lbs gain half a second.
Old Nov 19, 2008 | 08:42 PM
ThatGreenGsr's Avatar
pretty much all there is to it. the only performance gain is the weight reduction and it may lower the under the hood temp a little
tegman23
Aug 13, 2008 08:08 AM
Lude-acris
Mar 24, 2005 02:34 PM
oldbeefcake
12
Mar 4, 2004 11:24 AM
mugen92acintls
Mar 2, 2004 09:45 AM
black sohc civic
Feb 17, 2004 10:35 AM
