clutch issues
Old Nov 22, 2008 | 04:49 AM
beaterman's Avatar
Default clutch issues
today my clutch went soft on me and it is almost impossible to get into gear. the temperature dropped below 30 this morning which unusally cold for this area. my question is could it just be a temp. issue or do i need to check my fluid levels. if so then where is the resevior located for the clutch? thanks in advance.
Old Nov 22, 2008 | 08:51 AM
hunan beef's Avatar
same thing happen to me this morning.
Old Nov 22, 2008 | 08:55 AM
white4doorsi's Avatar
Check your fluid levels. Engage your clutch a few times and then check it again check to see if your fuid level has moved any
Old Nov 22, 2008 | 10:10 AM
beaterman's Avatar
where exactlly is the reservior at? i am at work and only have acess to a few websites, this being one of them. please help me so i can put some fluid in before i have to drive home tonight.
Old Nov 22, 2008 | 10:55 AM
VegasInvasion's Avatar
I'm Huge In Japan
If you have an actual Integra it should be just a few inches away from the brake reservoir around the vicinity of the brake booster on the driver's side firewall.
But if you're losing fluid in the cold then you have a 99% chance that your clutch master cylinder or slave cylinder is leaking. Or, there's a 1% chance that you just have bubbles in your clutch line, which can be bled from the slave cylinder on your transmission.
However if you have an OBD0 I believe the clutch is cable driven, so the year & model of your car would help also.
Old Nov 22, 2008 | 11:09 AM
beaterman's Avatar
99 ls integra
sorry i figured you would see it in my signature. my bad.
Old Nov 22, 2008 | 12:05 PM
I'm Huge In Japan
Sorry I never read signatures, most of them are just crap.
Yeah it should be next to your brake reservoir unless you bought it straight from Japan.
Old Nov 23, 2008 | 01:22 AM
beaterman's Avatar
thanks for all the responses i got home because of yall. thanks alot. the clutch still feels a bit soft but i will look at it more indepth on monday. also the fluid that was in the reservior was almost black. should i change it or is this normal?
Old Nov 23, 2008 | 04:49 AM
jayare05's Avatar
not that it has anything to do with your post.. but i checked ur teg out.. clean man..
Old Nov 24, 2008 | 12:35 PM
I'm Huge In Japan
That's not normal, it means you've been using the same fluid for 100,000 miles, and you need to have it flushed. It's worth the expense to save your clutch cylinders.
Jaydeep
Dec 1, 2011 05:35 AM
jlowellintegra
Nov 27, 2010 08:15 PM
Gomdohree
Apr 24, 2008 06:20 AM
sniperslayer
17
Nov 5, 2005 06:29 PM
Sex Cells
Nov 16, 2004 10:42 AM
