97 LS Coolant problems
Old Nov 18, 2008 | 03:57 PM
AWD Terror's Avatar
Default 97 LS Coolant problems
I had another thread before the change over, but I cannot find it. Mods, if you find it I will gladly post in there.
Car has 135k miles on it. Bone stock. I've was for a while getting random whiffs of coolant while I was driving the car. I tend to smell it after I have been driving it and stop for a light or a sign. I have searched the car everywhere for a leak and have come up empty handed. There is no oil in the coolant or coolant in the oil. I have changed both to be sure of this.
The temp gauge has been sitting right where it needs to be and does not fluctuate.
Today I smelled for the first time in a few weeks and checked the level. It was at the lower fill level so I have to be losing it somewhere. Any help would be appreciated.
Pertinent info:
Water pump, thermo, and heater core changed at 115k
Old Nov 19, 2008 | 06:17 AM
AWD Terror's Avatar
Forgot to add. Also changed the rad cap a few weeks back.
I'm starting a new job soon and don't want to have this car keeping me from going on my first few days.
Any input would be appreciated.
Old Nov 19, 2008 | 09:47 AM
AWD Terror's Avatar
TTT
Old Nov 19, 2008 | 04:18 PM
AWD Terror's Avatar
TTT
Old Nov 21, 2008 | 06:30 AM
AWD Terror's Avatar
nothing?
Old Nov 21, 2008 | 06:50 AM
K i l l a B e e.'s Avatar
sorry i can't help with your situation, because it looks like you've done everything i would check for.
https://honda-tech.com/forums/acura-integra-6/97-ls-coolant-smell-2419489/
i think thats your old thread if you're still looking for it.
Old Nov 21, 2008 | 09:33 AM
AWD Terror's Avatar
https://honda-tech.com/forums/showthread.php?t=2419489
Thanks man. I'm still stumped by this issue. I guess I'll just keep driving it until it gets worse
Old Nov 22, 2008 | 01:14 PM
AWD Terror's Avatar
BUMP
Old Nov 22, 2008 | 01:18 PM
562DA's Avatar
there is a bolt on the houseing of you upper radiator hose thatis conesed to the block that bolt could be warped or the housing itself can b cracked
Old Nov 22, 2008 | 01:42 PM
AWD Terror's Avatar
Please explain a little better. I don't fully understand where your talking about.
There are no visible leaks, but a crack somewhere is not out of the question.
Old Nov 24, 2008 | 06:21 AM
AWD Terror's Avatar
Bump
Old Nov 26, 2008 | 06:30 AM
AWD Terror's Avatar
Well I guess I'll keep this as a running log so I know when certain **** happens...
Check the level again today, and it's now got just a little bit lower than the full line. Last time I added was on 11/18/08 and I added to just above the full line.
caitb
Apr 26, 2015 06:22 PM
Wrona
Nov 29, 2011 01:01 PM
tianporn
Feb 26, 2011 10:58 PM
AWD Terror
Nov 5, 2008 04:26 PM
Harlowe
Honda Civic (2001 - 2005)
33
Sep 22, 2008 03:17 PM
