Changing axles
Old Nov 23, 2008 | 11:26 AM
luis31's Avatar
Default Changing axles
im changing out my axles today, anyone kno the proper torque specs for the screws i will be tightening down? or can someone steer me in the right direction?
Old Nov 23, 2008 | 11:52 AM
neardon's Avatar
I'm a Jackass
Google "hondahookup manuals" then download the manual for your car, it should have all the torque specs you need.
Old Nov 23, 2008 | 11:53 AM
BlueIntegraBoy's Avatar
Flange bolt at the bottom of the strut assembly on strut fork - 32 ft lb
Self locking nut at bottom of the strut fork - 47 ft lb
Castle nut on balljoint - 43 ft lb
Axle nut - 134 ft lb
Lug nuts - 80 ft lb
Old Nov 23, 2008 | 04:27 PM
gsrstick's Avatar
nice reply
Old Nov 23, 2008 | 08:45 PM
luis31's Avatar
thanks a lot for the help guys, unfortunately i couldnt get the ****in axle nut off. im so mad. i went thru 3 24" breaker bars. no luck. heated it with a torch. no luck. impact gun no luck. damn.
Old Nov 24, 2008 | 01:49 PM
berb_15's Avatar
I'm not trying to insult you if you did but did you bend the piece of metal on the nut out of the axle so it will spin freely (with a screwdriver or something)
nicky352
Jan 19, 2011 07:38 AM
rob42386
Feb 6, 2005 09:19 AM
SOcalistreetracer
10
Jun 12, 2002 03:37 AM
echo999
May 24, 2002 06:22 AM
Disco Monkey
Jan 13, 2002 08:32 AM
