90 integra issues
Old Nov 18, 2008 | 08:55 AM
DarkVtec EF8's Avatar
Default 90 integra issues
Okay it's my g/f's car and this is wat happens... She starts the car it runs good for just a sec. and dies.. she puts her foot on the gas to try and keep it runnin and it still dies, and you hear the intake suckin like crazy, as far as i know the fuel and spark is good, it just DIES, and if she keeps tryin it'll start and run fine.. but Just sometimes has its dead moments that it don't want to run?! Any idea's!?
Old Nov 18, 2008 | 09:40 AM
5litereater's Avatar
an CEL's? id say start simple and be sure your getting spark, fuel, and timing is correct. check your distributor cap and rotor. make sure youre fuel filter's clean. intermittent issues are tough to diagnose. does it act up when its cold? after it's warmed up? randomly?
Old Nov 19, 2008 | 04:29 AM
yea it could seem as though it was cold and the more we tried to start it, it go warmer.. but we were goin down the road one day and the car just cut off, and we tried to start it, ran for a sec, died again, waited a sec, and started just fine..?
Old Nov 19, 2008 | 10:28 AM
wasabivtec's Avatar
test the coil in the distributor there should be about 1.1 ohlms between + and -. if not replace it. That should solve the stall issue. As far as not restarting change out the main relay or repair the connections inside it. There is a how to at www.nzintegra.com
Old Nov 19, 2008 | 12:37 PM
super jdm yo's Avatar
i wanna go off and say it's the main relay, common in older cars to have that problem. my car did it too, and it was the main relay.
dsettlemoir
May 7, 2016 03:34 AM
ToTriggerHappy
Jun 8, 2010 07:52 AM
SOHC_civic_si
Oct 27, 2008 04:23 PM
sikluder
May 4, 2006 04:26 AM
