ABS Module buzzing...
Old Nov 15, 2008 | 12:43 AM
igone916's Avatar
Default ABS Module buzzing...
I have been searching about problems with the ABS module. It says there is an O-ring that I need to replace. If you have replaced yours before, can you tell me which ring it is on this picture...
http://www.acuraoemparts.com/d...ch=no
Old Nov 15, 2008 | 12:55 AM
majinsoftware's Avatar
When I first got my car the abs light was always on from it self testing every few seconds.(buzzing sound)
Replacing the Cap fixed the light and cut the buzzing in half.
Then wacking it with a bit of wood got rid of the rest of the extra buzzing. (Wacking it clears the air locks in the unit from having the cap leaking, Or if you have the service computer you can do it that way and bleed it.)
Now it only ever makes the buzz sound at low speed (under 20Ks) like it should when self testing.
Old Nov 15, 2008 | 08:59 AM
WERA689's Avatar
Default Re: ABS Module buzzing... (igone916)
I would bet on #23 in your diagram, at the bottom of the accumulator. That is what failed on mine, FWIW.
Old Nov 15, 2008 | 10:31 AM
Tegraracer90's Avatar
Default Re: ABS Module buzzing... (WERA689)
yeah i wondered about this too...it buzzes when i first start the car.....and sometimes wen i am sitting at a long traffic light.....is this normal or am i having a problem
Old Nov 16, 2008 | 02:48 AM
igone916's Avatar
Default Re: ABS Module buzzing... (Tegraracer90)
thanks...
Krusty_the
Mar 28, 2009 04:01 PM
Fliplm0de
Oct 5, 2005 05:41 AM
Audio28
Dec 22, 2002 11:48 PM
