will i have a problem using this ECU?
Old Nov 20, 2008 | 09:44 PM
Ricextacy's Avatar
Default will i have a problem using this ECU?
Vehicle: 1992 Integra GS
Engine: 95 B18B1 w/LS Cable Transmission.
And the Ecu is from a EG hatch, with an LS Swap.
its all OBD1, my only concern is that the EG's ecu was for a Civic not an Integra..
Old Nov 21, 2008 | 09:34 AM
Dartanian's Avatar
It doesn't matter what chassis the ECU comes out of as long as it has the correct fueling and timing parameters to run the engine it is controlling.
Old Nov 21, 2008 | 09:37 AM
AWD Terror's Avatar
Correct. If the ECU can run an LS in that car, it can run it in yours. May take a little time to get the wires right, but you'll get it.
Old Nov 22, 2008 | 05:40 AM
weavertime1's Avatar
As long as you use your '92 integra harness everything should be plug and play as the '92 - '93 DA is OBD1. Good luck!
CrazyHigh625
Jul 9, 2012 01:53 PM
nolanator6
Apr 4, 2011 04:56 PM
Eclectia
Jun 29, 2010 12:26 PM
eghatchfla
Apr 24, 2010 10:19 AM
eg6boii
11
Aug 31, 2008 09:05 PM
