help on timming
Old Nov 19, 2008 | 04:37 PM
john_lauj's Avatar
Default help on timming
i have a b17a1 motor. my timming is of. i cant seem to get right. i change the distributor, wire,spark plugs and belt and its still off. now my question is a b17a1 belt different from a b18c1?? cause when i had a 96 gsr i remeber the belt was shorter. also is it possible for b18a1 belt will fit on my motor?
Old Nov 19, 2008 | 04:48 PM
AnDThEnWuT's Avatar
What leads you to believe that your timing is off? Are you using a timing gun? Are your timing marks off? Need more info.
Old Nov 19, 2008 | 06:10 PM
slaminsam's Avatar
B17 is different than a B18c1 Im pretty sure it has the same deck height as a b16... And a b18a1 has a 19t water pump and vtec has more 21 maybe so no the belts are not the same.
Old Nov 19, 2008 | 06:14 PM
VTEC_PRODUCTION's Avatar
make sure all your parts are matched up for your car...dont be interchanging parts from different vehicles with different parts...formula for disaster...
Old Nov 19, 2008 | 06:55 PM
john_lauj's Avatar
when i put on my timming belt its off like 3/4 of a teeth. when all the marks r set the timming belt will sit on the cam gears teeth. also the timming gun shows that im off about a tooth but its not a tooth. just 3/4 of a tooth. when i drive my car, around 35-5 thousand rpm the car lack of power. feels like the cam are not meeting each other at the same time at top disc center.
Old Nov 19, 2008 | 08:17 PM
AnDThEnWuT's Avatar
are you just setting it at the cams or are you lining everything up, like the crank and the cam gears? And are you using anything to keep the cams from moving?
Sheela96
Dec 17, 2014 05:23 AM
VegaS10
May 20, 2013 12:05 PM
honda94accord
Apr 10, 2007 05:39 AM
civic_hatchback
Jun 10, 2004 10:23 PM
