Problems with the teggy.
Old Nov 18, 2008 | 07:11 PM
ank81006's Avatar
Default Problems with the teggy.
Delete please!
Old Nov 19, 2008 | 05:32 AM
weavertime1's Avatar
We need a little more info here...you may need to bleed your cooling system, also if it is leaking coolant that is not good. Identify where the leak is coming from and go from there. As for timing, you need to aim the gun down the timing sights on the timing belt cover. Hope that helps. Good luck!
Old Nov 26, 2008 | 05:13 PM
ank81006's Avatar
Delete PLs.!
slow-ef
Mar 26, 2009 10:53 AM
fast4imports
Jul 26, 2007 10:18 PM
Nicaraguense13
Sep 24, 2006 10:15 PM
musicncars
Jun 13, 2005 11:16 PM
worditsmenick
May 23, 2005 11:38 AM
