Alternator installation issues
Old Jun 25, 2016 | 06:36 AM
chazor's Avatar
Default Alternator installation issues
Hey guys after days of searching I haven't found any one that has/had the same issue I'm having. I have a 95 integra LS that I have to replace the alternator.The old alternators out, but I can't get the new alternator into the bottom bracket.Is there someething I'm missing?
Old Jun 25, 2016 | 09:39 AM
dazebreak's Avatar
Default Re: Alternator installation issues
When you match the 2 up, are their housings and mounting points exactly the same? Maybe you got a slightly different alternator.
Old Jun 25, 2016 | 07:47 PM
chazor's Avatar
Yea there exacly the same. the old one was tight getting out of the bracket as well.
Old Jun 26, 2016 | 08:11 AM
fcm's Avatar
fcm
Old Fart
If you look the alt. lower mounting bracket, [one side] has a "sleeve" inserted into the hole, it needs to be "pushed" out so the sleeve is flush with the inside of the bracket, it will self adjust as you tighten up the bolt. 94
Old Jun 26, 2016 | 08:16 AM
grjr's Avatar
The bottom bracket has a bushing on one side that the bolt passes through, when the bolt/nut are tightened down the bushing is pressed against the alternator to hold it tight. Before you put in a new alternator you need to move that bushing outwards a little to make room for the new alternator. You can do this by using a socket that fits over the bushing and a c-clamp to squeeze the bushing over into the socket. If you cant do that you could alternatively just use some sort of hammer to tap it in the direction you need it to go.
Old Jun 26, 2016 | 08:39 AM
chazor's Avatar
alright trying that now
Old Jun 26, 2016 | 09:58 AM
chazor's Avatar
So there is infact a sleeve on the bracket however its stuck in the bracket and not moving im keeping it doused with penetrating oil. ill let you all know what happens from here. I feel retarded but the way i pulled the alternator out i really couldn't see the lower bracket.
Pushed the sleeve back with a vise so problem solved thankyou guys!
bseballkid1990
Apr 27, 2012 08:47 PM
t_mac
Dec 18, 2008 06:30 PM
Phshorty
Dec 10, 2007 04:48 AM
Park
Dec 19, 2004 03:09 PM
