1997 skunk2 intake manifold and TB installation
Old 04-30-2016, 10:10 PM
johan60's Avatar
Icon4 1997 skunk2 intake manifold and TB installation
I put the skunk 2 manifold and TB on and hooked everything back up accordingly but it's revving high. Like if it wasn't for my launch control it'd probably be up to 6k. Does anyone have any idea what's the problem? The tps is set right and the map sensor is on and there isn't any leaks that I can find.
Old 05-01-2016, 06:15 PM
Prudz_lude's Avatar
Default Re: 1997 skunk2 intake manifold and TB installation
You have a leak from either the manifold gasket, throttle body, or the fuel injector seals. Very simple to fix.
Old 05-01-2016, 06:27 PM
johan60's Avatar
I think it's from the throttle body honestly. I checked it today. I just pulled it off and put the original back on until I can get a gasket due all the performance shops that carry them are closed till tomorrow.
Old 05-06-2016, 01:08 PM
guyver13's Avatar
did you not put a gasket on in the first place?
You should have put a fresh intake manifold gasket according to the head you have and a throttle body gasket; and make sure you tighten down each bolt (especially on the intake manifold) to spec and in order. Then check all vacuum hoses for holes and what not. Also check that your throttle cable is not too tight. At rest it should have slight play.
do those and you should be good
Wilka
09-03-2017 07:18 PM
Moonraker09
02-13-2013 08:50 PM
imcnblu
04-05-2012 02:28 AM
crazihobo
01-29-2012 09:41 PM
Quick Reply: 1997 skunk2 intake manifold and TB installation
