2k TEg Random Misfire?
I picked up a 2k teg w/ a random misfire for the most part it still runs and drives good ,but to get to the problem I started w/ plugs,wires, then I removed the cap to reveal a ton of rust and corrosion
Old Fart
Re: 2k TEg Random Misfire?
Ditto that^^^ replace the parts and when reinstalling cap replace the O-ring gasket, obviously it is leaking.
Good luck removing the rotor screw and the rest of the rotor.
Hint wrap a rag around it and soak it with a penetrating oil like Moovit and let id sit overnight. 94
Regular Series
06-24-2004 05:25 PM
