integra engine vibration
Old Aug 11, 2016 | 09:08 AM
fuzzysig's Avatar
Default integra engine vibration
having a lot of vibration in my integra
stock motor stock engine mounts with boltons
I got the usual symptoms
1 when I take off the light I get the throttle bounce bowwowow
2 when ac is on my steering wheel "shakes violently"
3 it is starting to shake at idle even without ac on
4 I tried to put hasport mounts in it from my other car and it vibrates very bad. I took them out after a month its impossible to daily
the other car has no problem with same exact same mounts
the mounts are good I just replaced them
I also tried urethane filled stock mounts and didn't help.
Old Aug 11, 2016 | 09:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: integra engine vibration
Remove belt from A/C compressor and try it, something is way out of balance I am guessing it may be the compressor clutch assembly as it changes when A/C is on or off. 94
Old Aug 11, 2016 | 03:18 PM
fuzzysig's Avatar
its starting to vibrate even without ac engaged. I noticed yesterday
the ac on vibration started happening in last 6 months or so
Old Aug 12, 2016 | 03:08 PM
fcm's Avatar
fcm
Old Fart
Evan with A/C off the A/C compressor clutch assembly is spinning, pull the belt, it is a cheap easy DIY way to confirm or eliminate the compressor as the problem, when diagnosing a problem, you have to start someplace.
You would then do the same with the alt. and power steering pump, [one at a time] to confirm or eliminate them as the problem
Also check the harmonic balancer, [crankshaft pulley] it may have "spun" outside rubber dampener may have separated from outside pulley or inside crankshaft mounting part, not a common problem but it happens and would start as a small vibration and get worse, you can see a problem with the crankshaft pulley by looking at it with the engine running, [most of the time] it will "wobble"
What year is your Integra ??? 94
Old Aug 15, 2016 | 03:19 PM
fuzzysig's Avatar
its a 2000 gsr
owned it for 2 years it just started happening.
but the bouncy motor was there all the time.
can the engine bounce be related to blown out suspension bushings?
Old Aug 21, 2016 | 10:42 PM
trm4life's Avatar
Originally Posted by fuzzysig
its a 2000 gsr
Check your crank pulley. It has a rubber damper. When the damper gets worn out the outer pulley can slip causing the alternator to get a weak charge. I'd also check ignition timing.
Old Sep 29, 2016 | 02:55 PM
fuzzysig's Avatar
Ok now im trying to figure out which would be more effective
urethane filled engine mounts with stock torque mounts or urethane filled torque mounts with stock engine mounts
I already tried all 3 motor mounts urethane filled with stock torque mounts and didnt like the amount of vibration
and i dont want to waste money on filling torque mounts if the result is the same amount of vibration at idle without improvement in engine rocking back and forth when i drop the clutch
Old Sep 29, 2016 | 04:24 PM
trm4life's Avatar
I have poly inserts in the front and rear mounts on mine, stock side mount and transmission mount. I have literally 0 engine rock, but when I shift 1st to 2nd, it's often a hard shift unless I have the rpms up above 3-4k.
1BADEGDC2
12
Feb 10, 2012 03:12 PM
spoolin_teg
Jan 15, 2008 11:39 AM
Thunder Cat
Jan 28, 2006 01:40 PM
