97 integra GS
I'm new to the Japanese import market, I've been driving BMW's. I just recently picked up a 97 integra GS for my sons first car. The car is in great condition body and interior wise, but the engine is bad. My question is will a b18c1 be a direct replacement?
You'll need a different ECU to run it and you'll need to add a wire for the VTEC solenoid, but the the motor should bolt right in.
If the car is an automatic its more difficult, I'm not aware of any drop-in ECU that will work for that.
Is the GS an auto or manual? If it's an auto you'll need a JDM B18C auto ECU since there is no USDM ECU that will work.
+1 to all this, and oil seals will wear a groove into the shafts over time, so if you can feel it with your fingernail, either sleeve the shaft or seat the seal such that the lips aren't lined up with the groove. Also the MyHondaHabit oil pan gasket is great, it's a bit expensive compared to OEM but definitely worth it.
If that's the case, and you don't want to do an auto to manual swap, have you considered swapping in a B20? The gear ratios in the auto will completely neuter the B18C even if you did get it all working properly, so you might as well save yourself $1500 and a lot of trouble. The B20 will drop right in and run with the same ECU, wiring, and trans no problem, and still have more power and torque than the stock motor if you opt for the high compression version.
That's a good point, I didn't realize you were in CA. If I recall correctly, the B20 is considered a "light truck engine" in CA so you won't be able to pass smog with it.
I think my eyes are bleeding from all the info I've been reading. Yeah I don't think it's going to work. Imy probably going to build my stock b18b1 to handle boost all new internals. I think that's going to be the easiest way to go.
R1Moon
Jul 21, 2007 04:02 PM
greebler
May 12, 2003 10:53 AM
