97 integra b20 swapped cooling problem
Im having a cooling issue myself wondering if anyone can give me a little help im doing my first motor swap on my own ive put a b20 into my 97 integra the problem i am having is iive notice my rad hoses arent full of coolant sometimes the top hose has some in it but i dont feel it in the bottom hose and it takes a while for that hose to get hot i replaced the thermostat i dont have any leaks checked my oil and its not milky my temp gauge doesnt say im over heating the lack of presure and the feeling of nowater in the hoses worries me even tho it says im not over heating any bit of help is greatly apreciated
Re: 97 integra b20 swapped cooling problem
Yes sounds like air in the system, make sure engine is very cool or cold, open radiator cap, start engine, put heat to full blast, and watch the radiator cap for air bubbles, use a funnel with a rag wraped around it and if its low in fluid top it off and watch untill the bubbles stop coming out and the hoses are hot and fans turn on with temp gauge at op temp the system should be bled.
BrandonSpringle
Honda CR-V & Element
10-29-2018 05:49 AM
