2001 Acura Integra LS idle issue
Hello,
I own a 2001 Acura Integra LS (Auto swapped to Manual). The Rpms at start idle 1k... after the car starts to warm up the car will drop down to 600 to 1000 RPMS over and over. I've looked for air leaks and the car has no check engine lights. I'm starting to get mad and would like another though on it. Thanks.
Engine = B18B1 (OBD2)
Harness = OBD2 V-Tec (Yes this is unplugged)
ECU = PR4 OBD1 w/ OBD1 jumper
Re: 2001 Acura Integra LS idle issue
Clean the iacv, did this come out of the blue or since the day you owned it?
I actually bought the car with the problem a week ago. I clean the iacv with carb cleaner and it seemed to change nothing so I ordered a new one which is in the mail. The one on it I think is also a auto one. Not sure if they're inner change able or not.
Replaced the Iacv and it idles at 2400 at cold start until fully warm and it drops to 1100 instantly.... it seem to idle a little better over all...
