Will a B20 swap pass smog
Old 06-15-2016, 04:12 PM
Kungfoohippo's Avatar
Default Will a B20 swap pass smog
I'm being told that a b20 swap might not pass smog in California if I put it in my 97 integra, is that true? Can anyone answer that.
Old 06-16-2016, 04:21 AM
TheRealTegger's Avatar
Default Re: Will a B20 swap pass smog
Since the B20 is considered a light-truck engine and the Integra is considered a passenger car, the answer would appear to be no.
You can read the details on BAR's website for yourself:
https://www.bar.ca.gov/Industry/Engi...uidelines.html
Particularly, see the first three Sections of that page.
Old 06-16-2016, 04:53 AM
spAdam's Avatar
No longer true. Call the BAR to confirm the details, but the B20 is now an approved swap. You'll need to carry over all of the Integra emissions and manifolding, so you'll be swapping in just the long block.
Old 06-16-2016, 03:49 PM
Geis's Avatar
Never was a problem as long as it isn't being inspected. I've had mine running years back and never failed a smog test.
Old 06-16-2016, 04:01 PM
I called them today. I'm waiting for a call back.
Old 06-17-2016, 08:23 AM
I just got off the phone with the "California bureau of automotive repair " spoke with the referee he said I can swap in the B20 as long as I use all the b18 emissions parts, manifolds,sensors, etc. So just the block. And before smog check the OBD II needs to be set to ready. So now I need to figure that out.
Old 06-17-2016, 08:41 AM
spAdam's Avatar
That's easier than you think. The B20 is externally identical to the B18, so the swap is exactly the same as putting in a new B18 long block.
As for the drive cycle, just drive it a round normally for a few days before getting tested. The smog shops won't charge you and will just tell you to come back of all of your readiness monitors are not set.
Old 06-17-2016, 08:43 AM
Old 06-17-2016, 08:44 AM
I'm super excited that just saved me a lot of money.
Old 06-18-2016, 09:56 AM
That's right. Drive it around normally for several days, if possible. You need a few full-cold to full-hot cycles and a variety of driving conditions for all the monitors to run their tests and report "Ready".
IMPORTANT: Make sure the gas tank is between 3/4 and 1/4 full. The EVAP monitor tests will not run (and thus cannot report "Ready") unless the gas level is in that range.
Old 06-18-2016, 09:57 AM
And you get the bonus of a bigger engine!
Old 06-19-2016, 08:08 PM
darksands's Avatar
I put a B20B in my 95 Special Edition. Straight swap, no after market parts, stock cat/exhaust. Passed smog without issues. If you have a guy that knows what to look for like the B20B stamp on the short block they might fail inspection but as far as the readings go it will pass no problem.
Old 06-20-2016, 12:32 AM
Shit Posts: 15
JDMswagSerf's Avatar
Good to see it can be bard now.
Will have to get mine bard.
Old 04-04-2017, 08:52 PM
CtDB7's Avatar
[QUOTE=Kungfoohippo;50949589]I just got off the phone with the "California bureau of automotive repair " spoke with the referee he said I can swap in the B20 as long as I use all the b18 emissions parts, manifolds,sensors, etc. So just the block. And before smog check the OBD II needs to be set to ready. So now I need to figure that out.
Hi I need some help with my swap so as far as swapping over all emissions what does that consist of? My car is a 94 integra with a ls motor so obd1. I swapped over dizzy, intake manifold. Question is my manifold doesn't have the vacuum pipe to accept the center hose that cones from the valve cover? Is there a certain year manifold to use?
Old 03-25-2018, 07:22 PM
KPDSM's Avatar
Does anyone know for sure...if I swap a b20 in do I HAVE to convert to obd2?
In other words, can I use all the OBD1 Integra emissions equipment and an obd1 computer with any b20 and pass?
Old 03-27-2018, 05:04 AM
jdmark1's Avatar
If your car is an OBD1 car, then of course you need the OBD1 Integra emissions stuff. It isn't a requirement to have and OBD2 car to pass emissions.
Old 03-27-2018, 07:02 AM
KPDSM's Avatar
Awesome! Thanks for response, looking for obd1 teg.
That makes my life so much easier/happier/better. B20 is the right price per potential to me. As long as I can use all the obd1 emissions parts to pass I think my swap will be pretty straightforward.
Old 03-27-2018, 08:10 AM
jdmark1's Avatar
Yea the reason this thread was talking about OBD2 stuff was because his car was an OBD2 car. Basically, you're just swapping you Integra intake manifold/throttle body/air intakearm and everything that's plugged into them such as all of the vacuum lines, hoses, sensors and all of that. You put all of that onto the rest of the B20 engine and there you go. And of course if you're trying to pass emissions and such, make sure your O2 sensor is working right, catalytic converter's good, and charcoal canister as well. Pay attention to how the vacuum lines are hooked up and redo them exactly as they were once you put it all back together on the B20 engine.
Old 03-29-2018, 04:38 PM
Krazy613's Avatar
I’m trying this on a obd2 integra. But in Ontario. I have two 98 integra’s and they changed there rules one month after I got a turbo 98(obd2) integra. So now I have to make a 98 integra b20v turbo pass on a obd2 ecu. I have to convert it back to stock computer for them to plug in and test ready codes. If anyone has any input I’m glad to hear it thanks. For the test I have a obd2 p72 stock ecu and stock injectors. I need a o2 for sure and see if I do have a canister.
Old 07-04-2018, 02:51 PM
KPDSM's Avatar
I've seen and heard this working for some, but never in person, only online. Whenever we had this issue in NJ we kept a stock ls computer, ebay ueader, stock injectors off to the side ... Swapped everything out every two years and back .Took two of us but we got it done in 2 days more than once on a few cars...Gl
Old 07-09-2018, 06:29 AM
Krazy613's Avatar
thats great info. Thanks gives me hope this might work lol. I’ll probably just sell the car after the two years since someone else built it. It’s beautiful but I can make my other Gsr body b18c5 the one I want. Thanks for the info
Old 07-10-2018, 11:02 AM
Fish Twig
tony_2018's Avatar
It is possible but you have to have your ecu in ready mode before they could scan. Which means driving around
Old 07-16-2018, 06:45 AM
Krazy613's Avatar
yeah im just worried since it’s turbo that something might screw up. Just gonna change injectors back to stock I have a stock p72 obd2 and will have to put a secondary o2 in and see how that goes if I can drive it to get the ready codes and probably fix the other codes might come up. Stupid me got a p72 with a knock board but I think I can have two codes not ready
Old 11-18-2018, 12:29 PM
ricksteggy's Avatar
What ECU did you use? obd2 p75?
Old 11-18-2018, 12:54 PM
-Intl Steve Krew
Caoboy's Avatar
For a 95 that’d be an obd1 p75
Quick Reply: Will a B20 swap pass smog
