need some help with my 90 da9
i have extremely alot of wear in my ffront tires...is there a way i could change all the wear on the inside of my tires only my front........please help ...tia
Old Fart
Re: need some help with my 90 da9
Wheel alignment, camber is way off, either because alignment is just off or suspension parts, [ball joints, springs, bushings ] are worn out. Your car is a 1/4 century old unless the front end has been done, my guess it is due for a major overhaul .
You can try an alignment, they are not that expensive and the shop will point out any issues you may have with the front end. 94
thanx for your suggestions.....i have a brand new skunk2 camber kit along with skunk2 coilovers same with the back but back is fine.....is there a way to take out the negitive camber on the front??
cash459
02-11-2004 03:51 PM
