New Turbo HP Upgrade
car b16a1 ef9 vtec turbo
hallo from germany.
i will change my setup for more horsepower
already i have low 240hp and 229torqe with small t3 /42/48 on 14psi
question....
i will change my injectors from 440 to 550 ccm ??? is this enough for 300-350hp
i will change my turbocharger from t3 to gt30/71 is this enough for 330-350hp
new clutch stage 3
new ecu managend programming.
must i made a new biger downpipe for the turbocharger???
request for statement
thanks.
hallo from germany.
question....
new clutch stage 3
thanks.
Re: New Turbo HP Upgrade
I think your 550cc injectors are still too small, consider 750cc. GT3071R is a good turbo but i would consider the GT3076 instead, its a little bit bigger but power comes on very hard and it still spools great. What size downpipe do you have now? 3" is ideal but if you have 2.5" that is ok for now if you don't have money for 3" though you will probably have to make a new downpipe because the GT turbo's are usually V-band.
550cc injectors to small with Walbro Fuel Pump for 350hp???? **** i have pay it and on order it??
and the turbocharger is not a gt30R witout R
it is a china turbo gt30 63 A/RA/R 70 /57
now my t3 donwpipe 2" is to smal like a fiat panda 50hp ,
my tuner build a new bigger downpipe .
550cc will be fine but don't push them any more then that(what I'm currently using). I wouldn't waste the money on a ebay turbo get a legit one and be done with hit.
I don't see why I'm not completely maxing out the duty cycle.
See the problem is blinx is everyone wants to play on the safe side or do as what ever one else does. For example on post 5 the OP doesn't need 3 inch to make 350whp he can use 2.5 its just going to have to be fine tuned.
i think you should consider 3076 instead of 3071, there is no noticable amount of spool gain from 3071 compared to 3076 and you will make more power with 3076 with a proper tune
Moderator
I like the GT3071R a bit better, with a much lower torqueband than even the GT3076R. especially with the smaller roads in germany, the nice quick straights and subtle chicanes, the GT3071R is a better choice IMHO.
With that said, I would at least go to 660 injectors or slightly higher. 550cc can do 350whp, but that duty cycle is really up there in the 80% range.
very cheap,but good ore bat quality
http://cgi.ebay.com/ebaymotors/CIVIC...Q5fAccessories
my target is not 350hp, i will tuned from 229torqe to 300 torqe , thats enough for my.
allso i use ride now a watter injection kit , how gives 10-20hp on my car.
thanks.
thanks.
OTHER QUESTION
can i run still the xs power manifold with a biger turbocharger like gt30r??
before i buy a 500 dollar manifold with thicker (bigger) diameters ???
http://media.photobucket.com/image/x...mcamera023.jpg
http://www.hondapower.de/forum/showthread.php?t=141144
Do yourself a favor and get a legit manifold. Im suprised that one hasnt cracked already.
Might as well try to find a good deal on a manifold/downpipe package
Moderator
OTHER QUESTION
lakiaccord
01-06-2004 06:06 AM
